Various Mk3, Mk4 & mk5 parts
Re: Various Mk3, Mk4 & mk5 parts
Postby Dave190 » Tue Nov 23, 2010 1:56 pm
Alright mate,got a steering column for a mk5?if so would you post?.
Thanks.Dave.
Build Date: 17.02.1999 --Vehicle Line: Transit 95 --Cab Style: Regular Cargo Van --Series: 190L
Engine: Diesel 2.5 (76PS) --Transmission: 5-Speed Manual - MT75 --Drive: RHD RWD --Axle Ratio: 5.14
Paint: Diamond White 73
Dave190
Postby trippydog » Tue Nov 23, 2010 2:16 pm
Dave190 wrote:Alright mate,got a steering column for a mk5?if so would you post?.
Thanks.Dave.
I've got a mk4 one, 92... part no. Not sure if it changed on the mk5's.
Former Van: '93 190 TD LWB High Top... Ex Police Riot Camper. Sad to see her go.
Check out our site, Go On Go Out if you are looking for live music in Portsmouth.
trippydog
Postby Dave190 » Tue Nov 23, 2010 4:07 pm
Ok,im not sure either,will try and find out and get back to you,if it does fit will def want it!!Cheers.Dave.
Dave190
Postby trippydog » Tue Nov 23, 2010 4:11 pm
Dave190 wrote:Ok,im not sure either,will try and find out and get back to you,if it does fit will def want it!!Cheers.Dave.
Ok, no prob. Full part no: 92VB-3C529-A2A
trippydog
Postby turnippits » Wed Feb 16, 2011 7:00 pm
have you got a spare wheel hanger for a mark 5 15 inch wheels :|
turnippits
Postby trippydog » Wed Feb 16, 2011 7:13 pm
turnippits wrote:have you got a spare wheel hanger for a mark 5 15 inch wheels :|
I think I might have.... did have one spare wheel hanger but not sure what size wheels it was for. Will have a look for you.
Thanks,
Si
trippydog
Postby trippydog » Wed Feb 16, 2011 7:31 pm
The one I have is a mk5 one but think it might be for 14" wheels:
trippydog
Postby turnippits » Thu Feb 17, 2011 3:18 pm
that is a 14 inch one mate i would have thought it would have been easy to get one but every one i have looked at is the same as mine siezed up :roll: :roll: :roll:
turnippits
Postby trippydog » Thu Feb 17, 2011 3:54 pm
turnippits wrote:that is a 14 inch one mate i would have thought it would have been easy to get one but every one i have looked at is the same as mine siezed up :roll: :roll: :roll:
Have you tried sites like breakeryard.com?
trippydog
Postby turnippits » Thu Feb 17, 2011 4:56 pm
found one thanks for your help everyone on ebay from transitparts.com 39.99+7.99 postage :roll: :roll: :roll:
turnippits
Postby turnippits » Mon Feb 21, 2011 1:49 am
do you have a pull out door step to fit the slide door on a smiley please as i carry two disabled relatives in my mini-bus turnippits
:roll: :roll: :roll: :roll: :roll:
turnippits
Postby trippydog » Thu Feb 24, 2011 12:50 pm
turnippits wrote:do you have a pull out door step to fit the slide door on a smiley please as i carry two disabled relatives in my mini-bus turnippits
No, sorry...
trippydog
Postby spooks » Thu Mar 03, 2011 1:07 am
HI DUDE I SEE YOUR BUSY THATS ALWAYS GOOD , I DONT SUPPOSE YOU HAVE A 2,5D 1996 CLUTCH PLATE I AM HAVING TRUBBEL TRACKING ON DOWN I KNOW IT SEAMS SILLY BUT A STANDARD 242MM AND THE HEAVY DUTIE 267MM CLUTCH DONT FIT THE ORIGINAL IS PROPPER MULLERD NOW, BUT IT HAS 6 SPRINGS IF THAT HELPS I TRYED TO FIT A 242MM CLUTCH PLATE AND PRESSURE PLATE BUT IT SITS WRONG IE IF I PUT IT IN ILL HAVE TO USE BIGGER BOLTS AND CRAM IT IN ? THIS SEEMS VERY ODD I CANT FIND THE FORD PART NO THERS NO GENERIC PART THAT MATCHES ? IM THINKING ITS MABY A ONE OFF CUSTOM AS THE GEARING IS QUITE HIGH IF YOU HAVE ANY INFO PLEASE COULD U FORWARD MANY, THANKS SPOOKS
spooks
Postby trippydog » Thu Mar 03, 2011 1:41 am
spooks wrote:HI DUDE I SEE YOUR BUSY THATS ALWAYS GOOD , I DONT SUPPOSE YOU HAVE A 2,5D 1996 CLUTCH PLATE I AM HAVING TRUBBEL TRACKING ON DOWN I KNOW IT SEAMS SILLY BUT A STANDARD 242MM AND THE HEAVY DUTIE 267MM CLUTCH DONT FIT THE ORIGINAL IS PROPPER MULLERD NOW, BUT IT HAS 6 SPRINGS IF THAT HELPS I TRYED TO FIT A 242MM CLUTCH PLATE AND PRESSURE PLATE BUT IT SITS WRONG IE IF I PUT IT IN ILL HAVE TO USE BIGGER BOLTS AND CRAM IT IN ? THIS SEEMS VERY ODD I CANT FIND THE FORD PART NO THERS NO GENERIC PART THAT MATCHES ? IM THINKING ITS MABY A ONE OFF CUSTOM AS THE GEARING IS QUITE HIGH IF YOU HAVE ANY INFO PLEASE COULD U FORWARD MANY, THANKS SPOOKS
Can't help you there, sorry.
trippydog
