Engines for Sale: Ford Transit MK2, MK3, MK4 and MK5
Postby TransitL0ver » Fri Dec 13, 2019 1:28 pm
All engines are working. Location: Poland (delivery possible).
Engine No. 1 -> 2.5 Diesel / 1990 year / code 4CA (Ford Transit MK3)
It has: oil pan, intake manifold, exhaust manifold, timing pulley, flywheel, clutch, Bosch injection pump (No. 366), orange injectors
Engine No. 2 -> 2.0 Petrol (2.0 EFI) / 1988 (Ford Transit MK3)
It has: alternator, oil pan, intake manifold, exhaust manifold, timing, pulley, power steering pump, flywheel, clutch, ignition apparatus, throttle
Engine No. 3 -> 2.5 Diesel / 1999 year / code 4HB / 4HC (Ford Transit MK5)
* 76 HP enhanced engine (banana engine)
Has: oil pan, intake manifold, exhaust manifold, timing, pulley, engine mounts, flywheel, clutch, Bosch 686-2 injection pump, orange injectors
Engine No. 4 -> 2.5 Diesel 1995 year / code 4FA (exchangeable for 4FB / 4FC) (Ford Transit MK5)
It has: oil pan, intake manifold, exhaust manifold, timing, visco, pulley, flywheel, clutch, Bosch 624-1 injection pump, green injectors, throttle, water hoses
Engine No. 5 -> 2.5 Diesel / 1997 year / code (Ford Transit MK5)
It has: oil pan, intake manifold, exhaust manifold, timing, visco, pulley, engine mount, Bosch injection pump No. 686, green injectors
Engine No. 6 -> 2.5 Diesel / 1996 year / code 4FC (convertible into 4FA / 4FB) (Ford Transit MK5)
* 70 KM
It has: oil pan, intake manifold, exhaust manifold, timing, visco + fan, pulley, engine mount, power steering pump, Bosch injection pump No. 624-1 (works unevenly, we add for free), green injectors, EGR valve, EGR tube , fuel pump, oil filler cap, water hoses, thermostat housing
Engine No. 7 -> 2.5 Diesel / 1992 / code 4DA (Ford Transit MK4 / 5)
* 80 HP, enhanced engine (banana engine)
It has: alternator, oil pan, intake manifold, timing, pulley, engine mount, power steering pump, flywheel, Bosch injection pump No. 415 (without ignition accelerator), white injectors, throttle, EGR valve
Engine No. 8 -> 2.5 Diesel / 1992 year / 4DA code (Ford Transit MK4 / 5)
It has: oil pan, intake manifold, exhaust manifold, timing, pulley, flywheel, clutch, Bosch injection pump No. 415, injectors, throttle, EGR valve
Engine No. 9 -> 2.5 Diesel / 1991 year / code 4CA (Ford Transit MK3 / 4)
* 70 KM
It has: alternator, oil pan, intake manifold, exhaust manifold, timing, pulley, engine mounts, flywheel, Bosch injection pump No. 366, orange injectors + damaged water pump
Engine No. 10 -> 2.5 Diesel / 1993 year / 4CC code (replacement for 4BC, 4FA) (Ford Transit MK 4/5)
* 70 KM
It has: oil pan, intake manifold, exhaust manifold, timing, pulley, flywheel, clutch, Bosch 431 injection pump, orange injectors, throttle
Engine No. 11 -> 2.5 Turbodiesel / 1992 year / code XXX (ford Transit MK4)
Features: Alternator, oil pan, intake manifold, exhaust manifold, timing, pulley, 1 engine mount, flywheel, EPIC Lucas pump, thick blue injectors, turbine
Engine No. 13 -> 2.5 Turbodiesel / 1993 (Ford Transit MK4)
Has: oil pan, intake manifold, exhaust manifold, timing, pulley, 1 engine mount, 1 flywheel, EPIC Lucas, mixed injectors, turbine
Engine No. 12 -> 2.5 Diesel / 1984 / Ford Transit MK2 / 68 HP
Code engine: 4AB
It has: alternator, oil pan, intake manifold, exhaust manifold, timing, visco + fan, pulley, 1 engine mount, flywheel, clutch, Lucas injection pump, injectors (unscrewed pipes), Vacum MK2 pump, thermostat
Engine No. 14 -> 2.5 Diesel / 1985 / Ford Transit MK2 / 68 HP
Code engine: 4AB
It has: alternator, oil pan, intake manifold, exhaust manifold, timing, visco + fan, pulley, 1 engine mount, Lucas injection pump, thick injectors, vacum pump, thermostat housing
Engine No. 15 -> 2.5 Diesel / 1984 / Ford Transit MK2 / 68 HP
Code Engine: 4AB
It has: alternator, oil pan, intake manifold, exhaust manifold, timing, pulley, 1 engine mount, Lucas injection pump, thick injectors, vacum brake booster pump.
Engine No. 16 -> 2.0 OHC Petrol / 1986 / Ford Transit MK3
Equipped with: Alternator, oil pan, intake manifold + carburetor, exhaust manifold, timing, pulley, flywheel, clutch, ignition apparatus
Engine No. 17 -> 2.0 OHC Petrol / 1979 / Ford Transit MK2
It has: Alternator, oil pan, timing, pulley, flywheel, clutch
Engine No. 18 -> 1.6 OHC Petrol / 1980 / Ford Transit MK2
It has: oil pan, timing, pulley
Engine No. 19 -> 1.6 OHC Petrol / 1981 / Ford Transit MK2
Engine No. 20 -> 2.5 Diesel / 1989 / Ford Transit MK3 / 4BA / 4BB
It has: oil pan, intake manifold + throttle, exhaust manifold, timing, visco + fan, pulley, engine mounts, flywheel, clutch, Bosch 567-1 injection pump, green injectors
Engine No. 21 -> 2.5 TDi (100 HP) with intercooler / 1998 / 4EC / 4ED
Has: oil pan
I'm Ford Transit Lover! Every generation - from MK1 to MK8!
I even have my own FACEBOOK FANPAGE which brings together lovers Ford!
Come and join!
TransitL0ver
Re: Engines for Sale: Ford Transit MK2, MK3, MK4 and MK5
Postby TransitL0ver » Mon Dec 16, 2019 2:47 pm
Another engines for sale!
Engine No. 22 -> 2.5 TDi (100 HP) / Ford Transit MK5 (1999)
Engine code: 4EB, converts to 4EC
Equipped with: alternator, oil pan, intake manifold, exhaust manifold, 1 engine paw, 1 engine mount, flywheel, clutch, turbine, thermostat housing
Price: 560 Euro
Engine No. 23 -> 2.5 diesel (75 HP) / Ford Transit MK5 (1999)
Engine code: 4HC, converts to 4HB
It has: oil pan, intake manifold, exhaust manifold, pulley, 1 engine paw, flywheel, clutch, Bosh injection pump 686-2, green injectors
Price: 590 Euro
Engine No. 24 -> 2.5 diesel (70 HP) / Ford Transit MK3 (1989)
Engine code: 4CA, changes to 4AB, 4BB, 4CB
Has: oil pan, intake manifold, exhaust manifold, visco, pulley, 1 engine paw, 1 engine mount, flywheel, clutch, yellow injectors
Price: 210 Euro
Engine No. 25 -> 2.5 diesel (70 HP) / Ford Transit MK3 (1988)
Engine code: 4AB, changes to 4CA, 4BB, 4CB
Has: oil pan, intake manifold, pulley, 1 engine paw, 1 engine mount, flywheel
Price: 190 Euro
Engine No. 26 -> 2.5 Diesel (76 HP) / Ford Transit MK5 (1995)
Reinforced engine, the so-called "banana engine"
Engine code: 4HB
It has: alternator, oil pan, intake manifold + throttle, exhaust manifold, timing, visco + fan, pulley, 1 engine paw, power steering pump, flywheel, clutch, Bosh No. 567 injection pump, white injectors, EGR valve, shield timing
Price: 560 Euro
Engine No. 27 -> 2.5 diesel / Ford Transit MK3 (1987)
Has: alternator, oil pan, intake manifold, timing, pulley, 1 engine paw, 1 engine mount, flywheel, clutch, Lucas injection pump (weak, sold as damaged), thick injectors
Price: 280 Euro
Come and join!
TransitL0ver
Postby hetman » Sun Feb 07, 2021 11:57 pm
Where are you located in Poland? And can you give us an update on available engines or other parts? Dziekuje.
Mike
hetman
