pinto 2.0l *SOLD*
pinto 2.0l *SOLD*
Postby LUCIFERV12 » Mon Apr 06, 2020 3:50 pm
https://www.ebay.co.uk/itm/283838398249
450£
i do have an adapter plate also to fit an mt75 on.
Here we have a genuine low mileage later 202 (1992) block, 2.0litre pinto from a 1993 ford transit.
Runs very well with no rattling, knocks or smoke, very quiet and smooth.
comes with twin webber carb with throttle linkage and cable that and electric choke that all works well.
comes with complete engine wiring loom including a basic ecu (controls the stepper motor on carb and advance on distributor) that justs plugs straight into the main wiring loom on all mk4 (1991-94) and mk5 (1994-2000 if doing a retro pinto conversion) ford transits so no messing about with wiring etc. (note this will work on diesel wiring looms already fitted if doing a petrol engine conversion on a transit)
although you can put a dgav carb and manifold and a vacuum controlled distrubutor if you did not want to use the one already fitted as these engines are very tune-able and parts interchangeable with other pinto types.
also comes with a steel tubular performance exhaust manifold. (i have the original cast iron one with what is left of the original complete exhaust system that will come with it)
still has the transit clutch/flywheel attached but can be interchanged with others if not using in a mt75 gearbox (1988-00)
the only things not included to make a complete listed below -
does NOT come with bottom crank pulley (that runs the belt to the water pump and alternator) so you will have to source your own
does NOT come with alternator or aternator brackets or water pump pulley so you will have to source your own (viscous coupling fan IS included though and is not seized)
back plate adaptor (to use on a mt75 gearbox) is available in other listing
pinto engine mounts for transit mk4 (1991-94) and will also fit mk5 (1994-2000) is available in other listing.
thanks for looking, see my other items.
Collection only from lyneham,
LUCIFERV12
Re: pinto 2.0l
Postby LUCIFERV12 » Mon Apr 13, 2020 7:25 pm
SOLD ****************************
LUCIFERV12
