Hi here we have a front axle off a county transit 4x4 , this is a complete front axle that I have had and is now no longer needed as I am on the later spec gear and this would of had to be a new set up just before we brought it . I have stripped it open so you can see how good the crown wheel and pinion are as these are known to get chewed up and worn out , as you can see its in excellent condition and the teeth are perfect , I have taken the pics so you can see what you are getting as these are very hard to find and in this condition .Like I said when I brought the transit this must long ago had a new set up and it shows, included is the actuator as well and theses are expensive on there own . There is a c clip that actuates the rod on the actuator that needs a new one or you make a c clip up easy enough .
Will come as in the pictures ,as you can see what you are getting .
This is a rare find as they don't come up often for sale and in this condition
For mk4 +mk5 transit countys
£400 collection from Swindon only on this
Sold as seen please check the pictures out
