mk4 crew bus / mk5 tourneo breaking for parts
Postby jamie182 » Mon Feb 01, 2021 7:41 pm
iv decided my mk4 project is never going to get done so all the parts I have collected to make the bus i wanted now have to go
i expect to strip it tomorrow so all the parts will be ready after that.
any items Can be collected from my work (working garage so were essential business and are open)
postage is also available on most items if it will go on a pallet
the van is still a full van with a load of good parts
time is against me I'm losing my storage so everything has to go i'm open to offers on everything!
i have a
    100ps Turbo diesel Engine and gearbox 2.5di with Bosch pump, new timing belt tensioner and water pump and brand new clutch (fitted in 2019 but done only been driven up the road and onto the 4 post lift) £650
    mk5 SWB prop shaft with new genuine ford center bearing £80
    4.11 rear axle £ 175
    set of 5 alloy wheels from a mk5 Tourneo (tyres need replacing) £180
    tow bar with caravan electrics £40
    full high spec dash wiring loom including front door looms, window regs, locking motors, heated electric short arm wing mirrors, Electronic speedo rev counter clocks, door cards, twin airbags with module, dashboard and all switches ect.. £100
    2 brand new front calipers with genuine ford discs and pads (been fitted but done less than 1 mile) £80
    front carpet from a Tourneo very clean no rips or tears £40
    set of mk5 front doors one rock solid other has the normal crack at the top, but other than that solid £50 each £80 for the pair
    tourneo gear stick with gator £20
    pair of glass headlamps £50
    pair of plastic headlamps with self leveling motors £40
    on everything else just send me and offer im not really sure what any of it is worth.
    mk4 doors 2 fronts and 2 rear mid top barn doors with glass. needs bottoms welding up.
    4 sliding side windows
    Mid top headlining with interior lamp
    manual adjusting clutch pedal
    manual accelerator pedal with cable and bracket.
    Pas rack with pipe work
    front subframe
    new full exhaust its for a Mk5 but modified to fit a mk4, might be good to someone i guess.
    Also have a load of repair panels that i was going to use
    have from N/s sill, inner arch and wing
    N/s step
    both rear arches full panel
    both side sills
    both rear inner arches (outer half)
    both rear spring hangers (box section that goes onto the rear cross member and holds the bushing for the spring shackle)
    Collection from Ng229ld
jamie182
Re: mk4 crew bus / mk5 tourneo breaking for parts
Postby Chris21r » Mon Feb 01, 2021 10:50 pm
Do you have any photos of the mk4 doors?
Do you have door cards and mirrors to go with them?
Also a mark 4 grill?
Chris21r
Postby jamie182 » Mon Feb 01, 2021 11:13 pm
I'll have a good look at them tomorrow and get pictures see what the condtion is ect and get back to you.
jamie182
Postby Maltesefalcon » Tue Feb 02, 2021 10:57 am
Hi,
I am interested to buy the front carpet.
Maltesefalcon
Postby jamie182 » Tue Feb 02, 2021 9:43 pm
Unfortunately the mk4 doors are rotten had a poke around today and both bottoms went though with a bit of pressure. Door cards are warped been wet at some point I guess.
I will try get the carpet dug out and some pictures taken.
Didnt quite get finished today so still got parts everywhere
jamie182
Postby Chris21r » Wed Feb 03, 2021 8:13 am
Ah ok.
What about the mk5 door cards? Are They any good?
Do you have a mk4 grill?
Chris21r
Postby jamie182 » Thu Feb 04, 2021 11:53 am
afraid the mk4 grill is already gone.
the mk5 door cards im trying to sell as part of a set for electric windows power locking ect.
https://www.ebay.co.uk/itm/224338812416
jamie182
Postby jamie182 » Sat Feb 06, 2021 3:41 pm
some of the panels i have to sell.
jamie182
Postby jamie182 » Sat Feb 06, 2021 3:43 pm
i have 2 of these
i have both sides of these.
jamie182
Postby jamie182 » Sat Feb 06, 2021 3:47 pm
jamie182
