Masses of Mk3/4/5 parts - far too much to list
Postby MinorMatt » Fri Oct 08, 2021 10:42 am
Guys I still have a huge amount of stuff for mk3/4/5 vans
New old stock, used, genuine and pattern - if you need anything give me a should and I will see if I can help!
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: Masses of Mk3/4/5 parts - far too much to list
Postby Chris21r » Fri Oct 08, 2021 12:30 pm
I'm after a MK4 slam panel, MK4 grill and NOS repair panels you might have?
Chris21r
Postby MinorMatt » Fri Oct 08, 2021 2:28 pm
you may want to list what you need?
I don't have a mk4 grille, but do have a NOS genuine slam panel, I have new bonnets (cant remember if I have a gen one), pattern front wings, dog legs, genuine B pillars, swb rear lower quarters (one genuine), genuine rear bumpers, semi high and higjh top rear doors, rear crossmember etc etc
2 x 2006 Mk7s
Postby Chris21r » Fri Oct 08, 2021 6:23 pm
For starts, I'm after wings and inner arch repair panels,
Would mind a section of A post on the passenger side where it meets the gutter rail.
Mine is a chassis cab so rear panels etc aren't any use.
Is the slam panel available?
PM me if you prefer.
Chris21r
Postby Chug » Fri Oct 08, 2021 7:54 pm
Got any front spring hangers Matt?
Chug
Postby MinorMatt » Sat Oct 09, 2021 11:48 am
Chug wrote:Got any front spring hangers Matt?
I only have pattern ones - 1 for mk3, and 1 for mk4/5. Its just thr way its worked out :lol:
2 x 2006 Mk7s
Postby gasbo » Fri Oct 29, 2021 7:40 pm
someone i know is after a wishbone left side
Attila Horváth shared his first post.
· 5d ·
Dear All, I need a huge help.
I have Transit 1986 (since 1987)
MK3 OHC vehicle.
I’m looking for a left control arm.
I ordered lot of piece but always arrived the “after ‘91” part under good order and parts number. Some guys wanted to selling me the transformed after ‘91 control arm.
I need a piece, contact in UK (which is willing to send).
Thank you.
gasbo
Postby MinorMatt » Mon Nov 01, 2021 2:36 pm
I've got one... but its attached to the complete subframe
2 x 2006 Mk7s
Postby joinerman » Mon Nov 01, 2021 9:49 pm
Have you got an alternator / power steering pump / tensioner pully Matt, 98 Mk 5 smiley turbo.
joinerman
Postby MinorMatt » Tue Nov 02, 2021 11:09 am
What do you mean by tensioner pulley?
I don't have a PAS pump in stock, but I do have an alternator (new and used) which would suit
2 x 2006 Mk7s
Postby MinorMatt » Tue Nov 02, 2021 12:57 pm
Wait a sec, do you have aircon? Aircon setups have a belt tensioner (I have a new one) and I have used aircon PAS pumps too
2 x 2006 Mk7s
Postby joinerman » Tue Nov 02, 2021 9:48 pm
Yes i have air con matt, only need the pully set up , pumps ok.
joinerman
Postby MinorMatt » Wed Nov 03, 2021 12:46 pm
Ahh ok, so you are just after the tensioner for the aircon belt?
Yes I have a new genuine Ford one £120 plus post.
The alternator bit threw me as its one a seperate belt to the PAS/Aircon
2 x 2006 Mk7s
Postby joinerman » Fri Nov 05, 2021 9:53 pm
I'll message you Matt.
joinerman
Postby conrod » Mon Nov 22, 2021 6:30 pm
do you have a good/new mounting plate for a steering box? Manual and PS box are the same, as you probably know!
conrod
