MK5 Transit 2.5di BANANA ENGINE (VIDEO RUNNING - WILL SHIP)
Postby soulysurfer » Thu Dec 09, 2021 9:28 pm
£345 Shipped, or £260 collected
(pic at bottom)
PLEASE READ ALL THE WAY TO THE END!
This is a running banana engine taken out of a smiley lasy week I took it out to replace with the turbo version which i have had sat in my workshop.
Please see video of the engine running last week:
https://filebin.net/hzx3deu1ro9s6s15/VI ... 081648.mp4
I can prove the milage from my van now if needed
IMPORTANT NOTES
Does include a lot of the pipes and fuel filter housing/pipes, injector pipes etc. Will take a pic soon of all the bits.
Does not include:
-Alternator
-gearbox
-all of the pipes/ancilleries (as some were used for the engine swap
Does include but with note:
- clutch (usuable but a bit worn)
-starter motor (not running very well i swapped to put better one on my van)
- fuel pump (the one from this engine went on my van as the one from the new engine wasnt injecting any more fuel with throttle - ive been told its probably due to some kind of rod that should move being stuck inside) this fuel pump was off an alleged 'recon' turbo 2.5 di - but it had been sat for a very long time. This is the one you will get in this auction
- one injector has one of the plastic nozzles on the side broken (can get pick if needed)
-injectors are missing plastic washers as they were needed in the engine swap
- rocker assembly is missing main bolts as needed on my van
- tappit caps of rocker assembly missing as needed on my van
Other notes:
- mechanic told me that the engine is pretty 'gooey' inside, said it was jusr very old gloopy oil.
- it ran very well and never failed me in the 6 years i had the van, i did try to do an oil change every year or so.
Any questions please ask - 0775299896
A man with a Van is like a Beaver with a log.
soulysurfer
