Mk6 Repair Panels (might fit MK7 also)
Postby Tosh52 » Tue Jun 14, 2022 10:15 pm
Is anyone interested in a job lot of the bits listed below for a Mk6 LWB RWD transit & possibly might also fit a MK7, I couldn’t finish the work due to a knackered shoulder.
What you get is as pictured
NEW PARTS
* 2No inner sills (driver & passenger door area)
* 2No outer sills (driver & passenger door area)
* 2No inner sill strips (to repair the inner sill on the sliding door side, enough to do from front to rear wheel arch)
* 1No inner sill panel (to repair the inner sill on the driver side this is the deeper section)
* 1No 2 part curved angle for rear inner wheel tub repair (this is for one side only)
* 1No Genuine Ford/Motorcraft Cat back twin silencer mid section exhaust (Done less than 500 miles)
* 1No exhaust rear pipe LWB aftermarket (as above done less than 500 miles
* Box of 6 weld through Copper Primer (Expiry date March 2030)
USED PARTS
* 1No Front inner arch passenger side (the part that the washer bottle neck passes through. Removed carefully from a downer vehicle & is in excellent condition, it’s just been roughly painted to protect it so will need sanding back to tidy it up,. They are over £80 for a pattern part & god knows how much from Ford.
Also included are all the thick card templates for all the repairs that I had already done on the van I made most of these slightly bigger so as I did you can cut out the rotten bits & leave the strength to weld the new fabricated sections to. (See photos)
SEE PHOTOS FOR ALL OTHER PARTS
THIS IS FOR COLLECTION ONLY FROM NORTHAMPTON
LOOKING FOR £300 the lot
Tosh52
Re: Mk6 Repair Panels (might fit MK7 also)
Postby trannyfreak » Sun Jan 29, 2023 11:19 pm
Hi is this lot still for sale?
trannyfreak
Postby Altransit » Mon Jan 30, 2023 12:20 am
