JOB LOT MK6 REPAIR PANELS “POSSIBLY MK7 & OTHERS”
Postby Tosh52 » Thu Jul 28, 2022 1:21 pm
Is anyone interested in a job lot of the bits listed below for a Mk6 LWB RWD transit & possibly might also fit a MK7 or others.
The reason for Sale is that I couldn’t finish the work due to a knackered shoulder.
What you get is as pictured
NEW PARTS
* 2No inner sills (driver & passenger door area)
* 2No outer sills (driver & passenger door area)
* 2No inner sill strips (to repair the inner sill on the sliding doorside, enough to do from front to rear wheel arch)* 1No inner sill panel (to repair the inner sill on the driver side this is the deeper section)
* 1No 2 part curved angle for rear inner wheel tub repair (this is for one side only)
* 1No Genuine Ford/Motorcraft Cat back twin silencer mid section exhaust (Done less than 500 mil es)
* 1No exhaust rear pipe LWB aftermarket (as above done less than 500 miles
* Box of 6 Pro XL weld through Copper Primer (Expiry date March 2030)
USED PARTS
* 1No Front inner arch passenger side (the part that the washer bottle neck passes through. Removed carefully from a downer vehicle & is in excellent condition, it’s just been roughly painted to protect it so will need sanding back to tidy it up,. They are over £80 for a pattern part & god knows how much from Ford.
Also included are all the thick card templates for all the repairs that I had already done on the van I made most of these slightly bigger so as I did you can cut out the rotten bits & leave the strength to weld the new fabricated sections to. (See photos)
SEE PHOTOS FOR ALL OTHER PARTS
THIS IS FOR COLLECTION ONLY FROM NORTHAMPTON
LOOKING FOR £300 the lot.
I WILL UPLOAD PHOTOS IN MANY BATCHES AS THE FORUM ONLY ALLOWS YOU TO DO 5 AT A TIME.
Tosh52
Re: JOB LOT MK6 REPAIR PANELS “POSSIBLY MK7 & OTHERS”
Postby Tosh52 » Thu Jul 28, 2022 1:25 pm
AND MORE
Tosh52
Postby Tosh52 » Thu Jul 28, 2022 1:27 pm
AND MORE
Tosh52
Postby Tosh52 » Thu Jul 28, 2022 1:35 pm
AND MORE
Tosh52
Postby Tosh52 » Thu Jul 28, 2022 2:09 pm
Apologies if I’ll this is confusing as every time I uploaded to Dropbox to share a link to the photos it just shuffled them into a random order, I’m really crap at this bulk uploading thing that don’t make it easy for a simpleton like me.
Hope the link for the rest of the photos works ok!!!
Tosh52
Postby Tosh52 » Thu Jul 28, 2022 2:10 pm
Here’s my Dropbox
Tosh52
Postby misterdog » Mon Aug 15, 2022 11:38 pm
Do you have the outer sill for under the sliding door ?
Thanks.
2002 Mk6 90 T350 2.4TDDI
misterdog
Postby Tosh52 » Tue Aug 16, 2022 8:48 am
misterdog wrote:Do you have the outer sill for under the sliding door ?
Thanks.
No sorry it’s only the parts above.
Tosh52
