Taken from Vanstyle website:
When it comes to suspension, Bilstein are regarded as the number one premium solution.
The TÜV approved German manufactured coilover kit will offer unrivalled performance & comfort as well as that desired stance so many people are chasing. The Transit Custom - dedicated kit offers lows of between 30mm & 50mm all round. A C-spanner is included in the kit to make altering the ride height of your van a doddle, even on the driveway.
The B14 product range from Bilstein is among the best that money can buy. Offering full height adjustability (front) as well as a much stiffer spring and damping rate, these components will drastically decrease the dreaded body-roll of the Transit Custom giving a much more planted feel in the corners.
The durable sporty springs are complemented by special spring plates manufactured from aluminium alloy. The fronts are CCC coated to prevent rust and give long term corrosion resistance.
Industry leading warranty of 2 years from the original purchase date.
If your budget allows, this is certainly the suspension setup to go for.
Set up:
Front: Height adjustable coilovers 30-50mm
Rear: Lowered rear leaf spring 40mm
The front of the vehicle uses height adjustable B14 coilovers (30-50mm lowering) and the rear uses a fixed (40mm) leaf spring.
Fitment:
Ford Transit Custom & Tourneo 2012-2018 Models
Ford Transit Custom & Tourneo 2018-2023
For vehicles with a 60mm wide leaf spring. Please ensure you check the width of your leaf spring before ordering. (Please see image for reference).
Contents:
x2 B14 Front Coilovers
x2 B6 Performance Rear Shocks
x2 40mm Lowered Rear Leaf Spring
x1 C-Spanner
x1 Fitting Kit & Documents
All specified lowering rates may vary approx. +/- 10mm depending on vehicle standard specification, options, tolerances & age. For example camper conversions, carrying more or less weight in the rear.
*After any adjustment to a vehicles ride height it is recommend the vehicle’s geometry is checked and re-aligned using suitable equipment. Failure to do can result in excessive and uneven tyre wear and in extreme cases even affect the vehicles handling. Please note Vanstyle do not offer an alignment/geometry service and alignment is NOT included within the Free Fitting Service.*
I bought the kit for my 2018 facelift custom sport 310 but never installed it so brand new in box. I have now sold the van so no longer required
Based in Horsham, West Sussex
£1100 Ono. (Out of stock at Vanstyle @ £1315.79)
