Hello do you have a single passenger seat as I'm after the plastic trim that's at the side also after the belt stork that's bolted to seat or even the drivers side one and bolt please?
A. This is an earlier Mk 6 they had anologue clocks... digis started around reg 03 but was also dependant on the actual build date of the van A. Only have a side slide door with a window
regards Nick 07779260143
Find a part for your MK6 Transit - Tel 07790046681
