Lucas Epic Pump for sale
Postby CraigMac » Sat Jul 31, 2010 10:46 am
Lucas epic for sale as I have coverted to a Bosch £70ono
Regards Craig
CraigMac
Re: Lucas Epic Pump for sale
Postby CraigMac » Sat Jul 31, 2010 11:29 am
I also have an epic pump with unknown fault which I will throw in with the sale if desired :D :D
Regards Craig
CraigMac
Postby dyak » Sun Aug 01, 2010 6:10 pm
Hi I am looking for a replacement pump for my 1996 auto A/C 2.5L Turbo Diesel in Australia. Numbers off the pump below. Let me know if what you have suits and is it a simple bolt off/bolt on job?
DSA1096
36355AUG
8720A011A
Lucas Pump
Cheers
David
dyak
Postby CraigMac » Sun Aug 01, 2010 6:46 pm
what is the problem with your old pump?
Regards Craig
CraigMac
Postby CraigMac » Sun Aug 01, 2010 6:51 pm
dyak wrote:Hi I am looking for a replacement pump for my 1996 auto A/C 2.5L Turbo Diesel in Australia. Numbers off the pump below. Let me know if what you have suits and is it a simple bolt off/bolt on job?
DSA1096
36355AUG
8720A011A
Lucas Pump
Cheers
David
yes the one i have will fit yours
Regards Craig
CraigMac
Postby dyak » Wed Aug 04, 2010 5:18 pm
I am in the UAE for work and friend who is looking aftre the Van said there was a fuel leak from the pump. He took it to Diesel specialist and they said it needed to be rebuilt. I ma not sure where it is leaking from but am home for 10 days next week so will see for myself. It also hunts" at idle which i was told is that the "weights" have worn also. Can the pump be simply replaced with another? i have read some blogs that say it needs to be programmed by Ford when i replacement pump is fitted. So i am a bit confused by it all. david
dyak
Postby dave.e.g » Thu Aug 05, 2010 10:02 pm
Hi there mate im looking for a lucas diesel pump for my 92 transit, Model 01255 EGG, Type 671, DPS 8520a480A is yours that pump if so could you contact me on 07960642290 please as will take it cheers Dave
dave.e.g
Postby Altransit » Thu Aug 05, 2010 10:05 pm
The EPIC doesn't need to be coded to the ECU, unlike the later systems :D but the pump does need to be similar to the original :wink:
Postby CraigMac » Fri Aug 06, 2010 8:08 pm
dave.e.g wrote:Hi there mate im looking for a lucas diesel pump for my 92 transit, Model 01255 EGG, Type 671, DPS 8520a480A is yours that pump if so could you contact me on 07960642290 please as will take it cheers Dave
No sorry Dave this is not the one for you :( however I may be able to get you one on Tuesday :D leave it with me :wink:
Regards Craig
CraigMac
Postby CraigMac » Fri Aug 06, 2010 8:14 pm
dyak wrote:I am in the UAE for work and friend who is looking aftre the Van said there was a fuel leak from the pump. He took it to Diesel specialist and they said it needed to be rebuilt. I ma not sure where it is leaking from but am home for 10 days next week so will see for myself. It also hunts" at idle which i was told is that the "weights" have worn also. Can the pump be simply replaced with another? i have read some blogs that say it needs to be programmed by Ford when i replacement pump is fitted. So i am a bit confused by it all. david
The epic pump I have will fit yours with no need for any other modifications :D it's simply a case of un bolting and changing over :D however the pump is very heavy and will be expensive to ship to you :?
If you still want the pump I can talk you through the change over from start to finish. It's really simple to change but the timing must be cock on to avoid a fault being recorded and the van dropping into limp mode.....
Regards Craig
CraigMac
Postby dyak » Sat Aug 07, 2010 8:17 am
Thanks Craig,
I have a friend who lives in Guildford so should be ok to send the pump to him.
I will then work out how to get it back to Australia.
Couple of Questions. Has the pump been rebuilt that you know of? As i have to get a mechanic to fit it (me being in UAE) don't want to go through the process again if this one starts to leak or other issues or how many miles/kms has this one done. Mine lasted 265000kms so i think that was pretty good. I am keen to get it. :D
Cheers
David.
Oh and how do you want to be paid. Do you take PayPal?
dyak
Postby CraigMac » Tue Aug 10, 2010 6:49 pm
Hi this pump has not been rebuilt but it has no leaks and is from a van that has done only 98000 miles or 155000km pay pal is fine there would be a small amount of postage to go on to the sale price as the pump is very heavy..... The change over is very simple however a garage will charge you a fortune... Really consider doing it yourself.... If your van was here I would do it for you.....
Regards Craig
CraigMac
Postby dyak » Wed Aug 11, 2010 5:22 pm
Hi Craig. That sounds good I will buy it. Can we do the transaction via email? my email is dyak@iinet.net.au. I fly back to Perth tonight for 10 days so will chat from there. I will also get the address for postage to my friend in Guidford as to Perth will be a fortune seeing it weights a ton. Will work out how to get it to Perth once it is at my friends house. Alternatively if you could find out how much it would cost to post to Perth West Australia and let me know that would be great. Thanks David
dyak
Postby dyak » Fri Sep 10, 2010 8:12 pm
Hi Craig.
Got the pump it is at my friends place in Guildford.
Just have to get it back to Australia now...
Can you email me the instructions on how to install especially the bits about lining up the timing so it does not go into limp home mode.
I have a mechanic friend linded up to do the swap.
Oh my email is dyak@iinet.net.au just in case you have deleted it.
Did you get to Transitmania?
Cheers
David.
dyak
Postby CraigMac » Tue Sep 14, 2010 7:22 pm
I can do that for you tomorrow... Although there are a lot on here Take a look at the links on my post about limp mode will put a few bellow!
Craig
Regards Craig
CraigMac
