Bought this sunroof 2nd hand to go in my Transit... but after much thought decided to go a different route, so before I put it on E-Bay, I will put it up here incase anyone has a project on the go...
It is a 50/50 split glass sunroof .... can open either drivers side, passenger side or both.. or release all clips and glass can be removed completely.
Has an interior light built into the centre divide bar (wires are short and will need new wires soldered on).
I have made up a template if wanted.
I have also sprayed it with a hosepipe and the seals are waterproof.
There is no other fittings and so new owner will have to fabricate clamps to hold sunroof in place.....the sunroof frame has tapped holes all the way around on the inside (M4 or M5 I think) so 25mm x 25mm angle with holes drilled would easily work to clamp the sunroof in.
Hole cutout for sunroof to fit will be 975mm wide x 515mm deep.
Each glass panel is 485mm wide x 465mm deep.
Glass is PPG Saftey Solarcool Solid Tempered Coated DOT 18.
I paid £50.00 for it and so thats what I am asking for it .......spent hours cleaning it and had to drive around the world to collect it
