EGR blanks..
EGR blanks..
Postby darkbluevanman » Fri Oct 22, 2010 10:45 pm
Got about 10, nowt fancy just mild steel 2/3mm (will check) £1.50ea inc post, paypal/P.O... :)
darkbluevanman
Re: EGR blanks..
Postby MrMPuk » Fri Oct 22, 2010 10:47 pm
For any particular engine?
Re: EGR blanks..
Postby bigjohnthomas » Fri Oct 22, 2010 10:49 pm
and what derivative might they fit "old chap" :?: :D
bigjohnthomas
Re: EGR blanks..
Postby darkbluevanman » Fri Oct 22, 2010 10:49 pm
MrMPuk wrote:For any particular engine?
Thought they were all the same (transits), they were quite poss' for LanRov??. but look the same as tranny (mk5 anyway!), will try and dig an old 'un out, hang fire on this for now...
darkbluevanman
Re: EGR blanks..
Postby darkbluevanman » Fri Oct 22, 2010 11:16 pm
60mm hole centres, which is deffo mk5 as I suspected, can't say what else! Oh, they're 3mm mild steel :) got about a dozen.
darkbluevanman
Re: EGR blanks..
Postby phatographer » Fri Oct 29, 2010 8:16 am
i'll have one, 078687168zero8
cheers
mk1 v4 - mk4 luton - mk7 350 115ps
phatographer
Re: EGR blanks..
Postby darkbluevanman » Sun Oct 31, 2010 10:06 pm
phatographer wrote:i'll have one, 078687168zero8
cheers
PM Me...
darkbluevanman
Re: EGR blanks..
Postby darkbluevanman » Mon Jan 10, 2011 11:07 pm
Found a few more, odd thin stainless one and some thicker steel ones, not much money, £1.50, £2 each delivered PM me.
darkbluevanman
Re: EGR blanks..
Postby jolly olly » Mon Jan 10, 2011 11:26 pm
On the 90T350 Dura Torx the blank plate i think the hole centres are 65mm, on an 03 85t280 i think the hole centres and plate were a bit smaller.
The overall size of the plate was 80mm L & 47mm W, so if theses plate are about this size they could easily be adapted by cutting one end to look like an open ended spanner.
Life is not a dress rehearsal
jolly olly
Re: EGR blanks..
Postby darkbluevanman » Tue Jan 11, 2011 9:22 pm
jolly olly wrote:On the 90T350 Dura Torx the blank plate i think the hole centres are 65mm, on an 03 85t280 i think the hole centres and plate were a bit smaller.
cheers olly.
darkbluevanman
Re: EGR blanks..
Postby gsi.turbo » Tue Jan 11, 2011 9:35 pm
are there any benefits by blocking the egr off?
gsi.turbo
Re: EGR blanks..
Postby BIG GEE » Sun Jan 16, 2011 9:33 pm
sent pm
BIG GEE
Re: EGR blanks..
Postby beachbum » Sat Jan 29, 2011 3:37 pm
my egr pipe is just beginning to go so is there any benifit from blanking them off ????
beachbum
Re: EGR blanks..
Postby gt_addict » Sat Feb 05, 2011 6:31 pm
Would these fit a transit connect? It looks the same shape although the ones i have seen have a nothc out on one side instead of a hole so you can slide it in without taking it apart completely.
gt_addict
Re: EGR blanks..
Postby fungshwai » Sun Feb 27, 2011 8:59 pm
you shipping overseas m8?
fungshwai
