hydraulic clutch
hydraulic clutch
Postby johnston » Sun Apr 02, 2006 7:02 pm
Hellloooo everyone!!!!!!!! newbie here just discovered the site
mate of mine has had me doin some work on a 2002ish transit rwd hes havin problems with the clutch basically no pedal you'd think it needs bled take slave cylinder out of bellhousing and give it a few pumps by hand and its great for a few days
so.......... how do you blled them as theres no nipple or is it just one of the cylinders thats buggered
thanx iain
johnston
Postby Nighthawk » Sun Apr 02, 2006 8:17 pm
My money would be on the master cylinder being faulty, it's casued a few problems over the years.
By the sounds of it, you have the original design slave cylinder which looks like it can't be bled.
Near where the flexy pipe attaches to the slave cyl, there should be a rubber cap on what looks like a small plastic pipe.
The flexy pipe has a small steel clip holding it in place, this clip has two positions of fittment, as does the flexy pipe.
with the cylinder fitted to the transmission, pull the steel clip out to the FIRST position.....not all the way out!
Now pull on the flexy pipe as if your trying to pull it out, the pipe will move back against the clip, the fluid will now be able to exit via the plastic pipe i mentioned earlier.
refit the pipe between pumps of the pedal as if you were bleeding anthing else :D
Nighthawk
Postby Turfman1965 » Sun May 07, 2006 10:20 am
THANKS 4 THAT I WILL TRY THAT 2MORROW. I HAVE FITTED NEW PARTS,(PEDAL AND GEARBOX)
Turfman1965
