Front door lock problem
Postby MrMPuk » Sun Dec 24, 2006 7:33 pm
I seem to remember from one of Nighthawks posts that it's up under the steering colum, I'd try a search if I was you.
Postby MrMPuk » Sun Dec 24, 2006 7:36 pm
Postby sc_BK » Sun Dec 24, 2006 8:11 pm
One of the fuses was missing :lol:
But now it keeps locking and unlocking, I presume that one of the doors aint locking right so it keeps trying? :?
Might just leave it until tomorrow as it's sub zero so the locks might be frozen up or somit, even the padlock on the shed was frozen solid!
sc_BK
Postby AndyG » Sun Dec 24, 2006 8:50 pm
For tommorow :lol:
Remove the drivers door barrel again and try the fuse :idea: Could be why the lock never worked (stuck in the wrong position) :!: :wink:
Postby sc_BK » Mon Dec 25, 2006 2:43 pm
Still aint had no luck with it :x
Just noticed hanging down in the pillar next to SLD there's this cable hanging loose -
Anyone know if that's lock related?
sc_BK
Postby AndyG » Mon Dec 25, 2006 7:00 pm
Can't be sure :( but that doesn't look like it's got anything to do with the C/L :!:
Check the back door wiring (as the drivers door lock trick didn't work)
Put the fuse in and try opening and closing all the doors.
MAKE SURE THE KEYS ARE IN YOUR POCKET :!: :!: :!: :lol: :lol: :lol: :wink:
Next thing I would do is to lock all the doors, and see if the motors stop cycling when the fuse is in. (with you inside)
Then try unlocking each door and see which one upsets the system :idea: Then we'll know what door to concentrate on :wink:
