Rear disc conversion!!!
Re: Rear disc conversion!!!
Postby Luke » Sat Mar 29, 2008 10:14 pm
here's a pic of the bracket and valve :D
Postby Gunslinger » Mon Mar 31, 2008 12:00 pm
very tidy :)
Gunslinger
Postby Luke » Sat May 16, 2009 9:32 pm
just to update this - the axle has now run 2000 miles trouble free - bigger bias valve did the trick :D
only problem is i've ruined the diff so ive decided to fit a non transit LSD axle
so ............. if anyones interested the axle and accosiated disk brake conversion parts are now (well as soon as i fit the next axle) for sale :!: :!:
Postby redeemer » Sat May 23, 2009 12:57 pm
So there is no LSD from later trannyies that would fit in the mk2 housing?
Nice and brillant conversion!
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Luke » Sat May 23, 2009 1:26 pm
redeemer wrote:So there is no LSD from later trannyies that would fit in the mk2 housing?
yes you can get them for mk3 that should just fit strait in :D but i just fancied another axle the 9.75" i'm fitting is supposedly good for 600bhp so whatever i do to the van i dont need to worry about the axle 8)
i'm bitten by this drag racing bug :mrgreen: - and once i get the twin turbos on i sould be able to make decent times 8)
Postby redeemer » Sat May 23, 2009 2:16 pm
If it wasnt for transport , I would take that! but it will be a lot $$$ to bring it to Malta :?
A 9kg injection pump (was outbid on a 145 pump :? ) was quoted 70 Gbp :shock:
redeemer
Postby ginsambo » Thu Jul 09, 2009 10:15 pm
It would be nice to put discs on a MK5 6 stud Twin wheeler! Got an axle to play with here!
Luke, did you press fit your discs over new studs with a longer non-threaded section or just keep them in place with the wheel nuts / wheel?
Just that I was reading up on a front disc conversion for an Econoline and from what I understand they supply new studs and advise press fitting the studs into the new disc and the hub. Makes changing the discs a bit of a bugger?
http://www.dddiscbrakes.com/installation.html
http://www.dddiscbrakes.com/installatio ... all-28.jpg
U know if Mk7 twin wheeler chassis cab rear brake discs have the 10 bolt hole fitting that bolts to the back of the hub or do they slip over the front of the hub with 6 holes over the studs?
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
Postby Luke » Thu Jul 09, 2009 10:17 pm
ginsambo wrote:Luke, did you press fit your discs over new studs with a longer non-threaded section or just keep them in place with the wheel nuts / wheel?
just kept them in place with the wheel nuts / wheel :D with the merc disk i used it's not necessary to centre the disk with the studs as it uses the hub to centre it :D
Postby Luke » Thu Jul 09, 2009 10:18 pm
i'm getting the hang of this disk conversion lark now :lol: just done it to the new axle :D
Postby ginsambo » Thu Jul 09, 2009 10:36 pm
I scavenged a rear stabiliser bar off a 190 hi-top this evening have to say that welding is a lot better than what I saw on the factory axle. Is that smoothrite metalic paint?
All you are missing is the T5 box now? :D
ginsambo
Postby Luke » Thu Jul 09, 2009 10:39 pm
ginsambo wrote:Is that smoothrite metalic paint?
no it's supposed to be hammered black but its more like smooth grey but it matches the van so it'll do :lol:
ginsambo wrote:All you are missing is the T5 box now? :D
mabe - got to break a few MT75's 1st tho :lol:
Postby camper extraudinair » Thu Nov 29, 2012 7:42 pm
Hi Luke
If your going to change the rear axle for a lsd
with discs i have fitted a trans am rear axle
from a 1999 with 3.2 ratio lsd & large vented
discs & handbrake in disc.
I am using xjs front brakes & have had no
trouble with the compatability between the
two.
Also the pcd is the same on both.
I must say i admire you for your dedication
determination & hard work you have put into
the convertion good luck in your future efforts.
camper extraudinair
Postby Luke » Thu Nov 29, 2012 8:48 pm
camper extraudinair wrote:Hi Luke
If your going to change the rear axle for a lsd.
allready done it mate :D there are some pics on here i fitted a 3.77 dana 60 from an F150 lightning - i redrilled the PCD to match my 5x112 as i love the wheels ive got and havent got any plans to change them :D
camper extraudinair wrote:I must say i admire you for your dedication
same to you :mrgreen: - very interesting conversion you did with the xjs to transit front hubs 8)
