Flame start timings.
Postby vanfox » Thu Dec 06, 2012 5:27 pm
As it says, would someone who has a flame start system kindly furnish me with the timings for the system as in, how long the plug glows before the fuel valve opens, how long the fuel flows for and how long before you turn the key to start?
OR, has anyone got a flame start system less the plug for sale?
vanfox
Re: Flame start timings.
Postby robbie.cee » Fri Dec 07, 2012 4:19 pm
Usually only a squirt of fuel from the leak off or a dedicated reservoir.
Only. Needs a little bit to generate heat in inlet...
Hope this helps.
Would imagine about 5 or so seconds to fully heat flame plug ...
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby MinorMatt » Fri Dec 07, 2012 4:29 pm
The factory setup pulls the diesel from the top of the fuel filter housing without a pump. The pressure generated when cranking forces the diesel out. (Presumably there is a shut off solenoid too - but I can't remember)
As soon as the van has started its redundant... so I would take a power feed off the starter wire
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby knighty1981 » Fri Dec 07, 2012 5:13 pm
only one I've seen was on my Iveco daily
fuel came from the back of the injection pump, under pressure from the lift pump next to the fuel tank
(had a small solenoid to turn it on/off)
it only ever ran when it was really really cold... -5'C etc..
light would come on with ignition to say it was working, go off after a good 30sec or more, then you start it, and it would come back on for another 2min while the engine was running
planning going somewhere cold ?
knighty1981
Postby vinny55 » Sat Dec 08, 2012 9:05 am
Hi I am a geordie and i live in the polish mountains, 1999 tranny crewcab pickup I have flame start as std and it is on for 20 sec but it is set to come on at -15c last year it started first turn of key and it was -52c yes thats *******g cold,hands stick to doors when you try and get out of house never mind tranny,but she has never been stuck in snow or never started snow tyres chains help and today its -20c and 3ft snow and i am still out in tranny.
vinny55
Postby transit-liberty » Tue Feb 19, 2013 10:38 pm
I have removed my flame start system but not the manifold glow plug so if anyone wants it make an offer.
God help us all!
transit-liberty
