Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Tue Nov 27, 2012 9:31 pm
Jammed/screwed either way i got spare parts now plus spare v6 electronic ignition module i may as well flog...
be good to get it spot on too so the timing gun will be well helpful, especially as you can dial in the advance on the rear of the gun....'kin awesome! :D :D
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Dec 01, 2012 10:47 pm
So today got up early , timing gun in hand out to pick up new dizzy..
Waited hour then went home, miffed but happy cos I timed my dizzy with new gun...
Loads better at 14 degrees advance, even with seized weights in my old dizzy.
Got home, fast, and after coffee spoke to guy in shop, arranged to get back down after brew
Now he was on his way.....
So got there got old one out after popping cap and moving to tdc and rotor on #1...
Basically new one in bit after much messing got a tow home as needed to go shopping.
Another silly easy job gone sour
:twisted:
So ill be out playing tomo, but hopefully end in sight so ill be able to drive her more!
Faster too lol...
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Dec 02, 2012 2:25 pm
So a good nights sleep later and a good think and a few backfires, turns out I had somehow got it 180 degrees out lol
Now running like a dream , with full mechanical and vac advance,
timed to 16 degrees static ,no vac...
Once blowing manifold sorted (got gaskets) ill set to try to improve my 7hg in from vac advance supply.
Already took ages to warm up today so, gentlemen, I might be on way to proper running !
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Dec 02, 2012 3:13 pm
Well done Rob, keep at it :D
Postby robbie.cee » Sun Dec 02, 2012 6:11 pm
I gotta say BIG UP to Mark, Whitemice, for his properly intuitive info on timing and vac settings!
Had
MAKE IT FIT
robbie.cee
Postby mobilevanman » Mon Dec 03, 2012 12:10 am
remember my phone call robbie i said "sure youre not 180 out" u said you didnt take cap off so i left it glad it working now
why not if u dont someone will
mobilevanman
Postby robbie.cee » Mon Dec 03, 2012 9:05 pm
Must have moved a tooth or two cos I defo set #1 to tdc and double checked rotor was at lead #1!
Any how's its running fekin sweet, if u can get clutch operation fully will be such a fun drive
Got a 4 month old V6 electronic ignition for sale
30 quid posted, 40 fitted if anyone wants or needs one !
Cap'n, I be needing those seat legs soon matey!
Will defo call you soon !
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Dec 05, 2012 10:06 am
Sweet 5 meters of 5/8 inch heater hose on,its way for the rear heater !
Good old ebay. 13 quid posted not bad...
Best be tidying back out soon to make space for seats and to work !
Can't wait to get out for a rip up the motorway now all is well on timing front!
And now its snowing
Typical
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Dec 05, 2012 3:35 pm
Typical... snowing in Essex but not Snowdonia... :?
Postby robbie.cee » Wed Dec 05, 2012 4:02 pm
That's probably a good thing ain't it? Lol
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Dec 05, 2012 4:07 pm
Not really... I like the snow...
Its sunny here and I can't even see a cloud from the window
Postby AlanN » Thu Dec 06, 2012 12:54 am
Snow has turned into 2" of ice now, leave it until the sun comes out Rob
Postby robbie.cee » Thu Dec 06, 2012 11:34 am
Tell me about it had to get 4 new tires on Mk7 as they was balder than harry hill...
Can move now which helps on roundabouts
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Dec 12, 2012 10:58 pm
Well the day wad today got to drive the van after new dizzy was fitted last week...
Fkin sweet is all I can say, just really really need to sort this clutch arm end thingy and it'll be so sweet.
4th gear round roundabout 20mph, loads of torque so luckily not too much gear changing!
Once I fitted new exhaust gaskets, ill do the vacuum tuning that WHITEMICE posted up!
Then tidy out rear and get seats fitted!
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Wed Dec 12, 2012 11:55 pm
Sounded Sweet when you left mine 8) 8) 8)
captain hook
