Fuse box wiring question
Postby Alaleuile » Fri Dec 14, 2012 9:29 pm
Hi,
I'm a little bit confused about how to connect my fuse box to my leisure battery. I have an 8-way blade fuse box (like this one: http://www.autoelectricsupplies.co.uk/p ... ategory/63), so it has 8 input terminals and 8 output terminals. Does anyone know the best way to connect the single positive feed from the battery to the 8 input terminals on the fuse box? Is there something I can buy that will join the input terminals together (a busbar or something), or do I need to somehow split the input wire into 8?!
Or have I bought the wrong kind of fuse box...?
Alaleuile
Re: Fuse box wiring question
Postby TIMO » Sat Dec 15, 2012 2:38 am
I,d just make my own buzbar mate .
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby ake » Sat Dec 15, 2012 9:56 am
Buy decent sized spade terminals (yellow insulation) and loop the cable from one to the next using some 2.5mm cable, or put one spade on each with a short length of cable, and then join all the cables in a decent connector block, or with a nice soldered connection
Postby suffolkboi » Sat Dec 15, 2012 10:53 am
I just soldered a lenght of heavy wire across the terminals.
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Postby Alaleuile » Sun Dec 16, 2012 11:30 am
Thanks for all the advice, guys - problem solved... :D
Alaleuile
cron
