van wont stay on tick over after slave cylinder change
Postby dye29 » Mon Dec 17, 2012 5:15 pm
hy all as you no i had my gearbox out to change slave cylinder but while there put new flywheel and clutch in just got her back together started her and it fires up but as soon as i let go of key it dyes any ideas ive fully checked everything but clueless now
dye29
Re: van wont stay on tick over after slave cylinder change
Postby liteace » Mon Dec 17, 2012 8:10 pm
Maybe a damaged or unplugged crankshaft position sensor, I think its on the flywheel end
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby gt_addict » Mon Dec 17, 2012 8:20 pm
As said above check the crankshaft sensor. Only £20 for a ford one if it is knackered.
gt_addict
Postby dye29 » Mon Dec 17, 2012 10:56 pm
is it easy to find also can i have touched it while doing flywheel
dye29
Postby liteace » Tue Dec 18, 2012 2:12 am
dye29 wrote:is it easy to find also can i have touched it while doing flywheel
Yes you could have touched it, the back of the flywheel (engine side) is the reluctor for the crankshaft position sensor, if you look up under the van, where the right hand side driveshaft goes into the g\box, its just above in the engine block facing the back of the flywheel, if the sensor is good then maybe its the wrong flywheel :(
liteace
Postby dye29 » Tue Dec 18, 2012 5:48 am
ye was just having a think about that the flywheel is identical to other and it cant be on wrong theres only one way to fit it ,if it was a sensor or wire loose woudnt i have a light on dash also i dont think it will be an earth cos it wouldnt even fire up if it was, ill check crankshaft sensor today after that im clueless again
dye29
Postby tez » Tue Dec 18, 2012 9:40 am
crank shaft senors are very easily damage and if ya caught it while dropping the g/box out .. could of damage it even though it looks ok :? , have ya tryed to clean with a little petrol or sumit to remove the crap on the tip that reads the crank or theres a bit of oil or grease on the fly wheel coursing it to run lumpy just a thought :?
tez
Postby liteace » Tue Dec 18, 2012 1:53 pm
tez wrote:crank shaft senors are very easily damage and if ya caught it while dropping the g/box out .. could of damage it even though it looks ok :? , have ya tryed to clean with a little petrol or sumit to remove the crap on the tip that reads the crank or theres a bit of oil or grease on the fly wheel coursing it to run lumpy just a thought :?
Its not going to get damaged when removing the G\box as it sits behind the flywheel + oil will not affect it as some of them on other vehicles are fitted in the crank case and thats got oil splashing about when the engine is running
liteace
Postby dye29 » Tue Dec 18, 2012 5:29 pm
hy again ive checked all the plug connectors i unplugged all ok and only go in one ways so cant get them wrong , unplugged crankcase sensor looks clean and ok , starters kicking in and fireing engine up but dies straight away has anyone any other ideas im deffo clueless now
dye29
Postby liteace » Tue Dec 18, 2012 8:09 pm
Looks like you going to have to get someone to plug in diagnostic machine and look at the live data to check see whats going on, or not going on
liteace
Postby dye29 » Tue Dec 18, 2012 8:20 pm
that sounds pricy , am i right in thinking if there is a problem the engine management light would come on
dye29
Postby taz666 » Tue Dec 18, 2012 8:56 pm
i know this may seem a stupid question but are the 2 large connectors fully connected?, also is the van a di or ci and is the correct flywheel fitted, also i know this normally applies to big transits but have you connected the speed sensor wire to the crank sensor and vice versa
taz666
Ford Technician
Postby dye29 » Tue Dec 18, 2012 9:01 pm
yep connectors fully connected , its the identical same flywheel , mines the tddi and the speed sensor im not sure where it is i just plugged the plugs back to where they were and my engine run perfect before i took gearbox out
dye29
Postby taz666 » Tue Dec 18, 2012 9:21 pm
im sure the speed sensor is down the back of the box and has the same connector but i might be wrong, havent done a connect in a while, does the speedo move when cranking?
taz666
Ford Technician
Postby dye29 » Tue Dec 18, 2012 9:29 pm
no def not i read that somewhere if it moves there wrong way around , it fires up normal then cuts out a sec later its blooming anoying now as it was perfect , if the crank sensor was nackered it wouldnt even fire up would it same for any other sensors/plugs, any more ideas taz im stuck :?
dye29
