ENGINE WEIGHT
ENGINE WEIGHT
Postby dave the brave » Wed Aug 24, 2005 9:29 am
Dose anyone know the weight of a 2.5 DI engine with starter/alternator fitted ? :?:
LIFE IS TO SHORT SO LIVE A LITTLE.
dave the brave
Postby MrMPuk » Wed Aug 24, 2005 10:21 am
With or without fluids?
Postby WINDSCREENGUY » Wed Aug 24, 2005 1:51 pm
before or after dinner?
and does this engine make my rear end look big? :D
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby dave the brave » Thu Aug 25, 2005 11:36 pm
with fluids Mr Mpuk thanks. & i dont realy want to look at your rear end to know gray van man.
cheers
Dave
dave the brave
Postby transitgeoff » Fri Aug 26, 2005 7:23 pm
well one thing i know about the 2.5 di engine, with or without fluids and before or after dinner, if you drop it on your toe it bloody hurts :wink:
transitgeoff
Postby madmark » Fri Aug 26, 2005 7:27 pm
:lol: :lol: yes very heavy mind you the essex isnt much difrent , will have to pump the tyres up to 55psi :lol:
Postby transitgeoff » Fri Aug 26, 2005 7:32 pm
is it in :shock:
transitgeoff
Postby madmark » Fri Aug 26, 2005 7:49 pm
no not yet mate :(
Postby Luke » Fri Aug 26, 2005 10:53 pm
OK guys anyone got an answer :? with or without fluids :lol:
i do believe the V6 weighs 167KG but ive no idea about the Di!!
:D
Postby dave the brave » Mon Sep 05, 2005 11:46 pm
OK guys.
come on surly one of you has an engine lying around near a way bridge. just set it on & print it on the forum.
cheers.
dave the brave
Postby MrMPuk » Mon Sep 05, 2005 11:47 pm
Why do you need to know?
Postby Luke » Wed Mar 15, 2006 8:42 pm
I have the answer....................... well sort off :?
a Di complete with oil, alt, flywheel & clutch starter (small one) and MT75 Gearbox (also with oil) weighs 300KG :D
so how much does an MT75 weigh :?: - if no-one has the exact weight i'll weigh one soon!! :D
Postby Rolo » Thu Mar 16, 2006 1:38 am
Engines and gearboxes weight chart:
http://www.241computers.com/ford/Conten ... 30-38.html
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby baconsdozen » Thu Mar 16, 2006 8:00 am
And its all in pounds,not those horrible kg things.
baconsdozen
