A girls guide to the mk4
Re: A girls guide to the mk4
Postby linsey_young » Thu Nov 15, 2012 1:37 pm
It's the type 34 square axle by the way :)
If I knew then what I know now, I'd have taken it to the scrapyard...
Glad I didn't though :)
linsey_young
Postby MinorMatt » Thu Nov 15, 2012 10:10 pm
A 4.56 or a 4.11
If the diff is out its really easy to find out... count the number of teeth on each gear and divide them...
It should also be marked on the writing on the outside edge of the flywheel (I don't know the numbers, but it will be something like) 11/50 or 9/37 etc
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby linsey_young » Thu Nov 15, 2012 11:29 pm
Ah, of course! I work gear ratios out all the time on bike transmissions... Never thought to just count the teeth :oops:
linsey_young
Postby linsey_young » Fri Nov 16, 2012 9:21 pm
Not supposed to look like this...
Should look like this instead...
linsey_young
Postby MinorMatt » Fri Nov 16, 2012 10:29 pm
pinion bearing knackered then...
2 x 2006 Mk7s
Postby linsey_young » Wed Nov 21, 2012 1:19 am
She lives! Home at midnight - but at least I drove back! Bath then bed...
linsey_young
Postby linsey_young » Sun Dec 16, 2012 4:20 pm
Meh, three and a half weeks back on the road and now cooked the engine :evil:
I've managed to source a banana motor to replace the lump in it at the moment. More power, bosch pump and (hopefully) no oil leak, so silver linings and all that. Is there much of a difference between the older 2.5di and the later banana with regards to swapping them over?
linsey_young
Postby oldyellar » Sun Dec 16, 2012 4:26 pm
linsey_young wrote:Meh, three and a half weeks back on the road and now cooked the engine :evil:
very easy swap blank off the egr on the bannana and also may be worth taken the bannanas off and power washing them out as the will be clogged up :wink: you will also need to wire a stop switch upti the fuel pump
oldyellar
Postby dieselhead123 » Sun Dec 16, 2012 8:17 pm
As above, but try to get the new engine complete with bottom rad hose, there is a difference between early and late fitments as the water coupling at the back of the engine front plate, behind/under the injection pump, is different between early and late types.
Provided you use the hose that comes with the engine it will fit to your rad.
Postby MinorMatt » Mon Dec 17, 2012 10:39 pm
you will also need to swap the engine mounts from the mk4 on to the mk4 engine
2 x 2006 Mk7s
Postby oldyellar » Tue Dec 18, 2012 11:50 am
thgink the are diff so just put your mk4 ones on your mk5 engine
oldyellar
Postby linsey_young » Thu Dec 20, 2012 9:33 pm
Todays progress after I got it into the shed...
Hopefully get the lumps swapped on Saturday if all goes to plan...
linsey_young
Postby linsey_young » Sat Dec 22, 2012 4:03 pm
New lump successfully moved from the scrappie :)
76ps of raw diesel power! :twisted:
Removed from an LDV convoy - finally going into the right van!
linsey_young
Postby MinorMatt » Sat Dec 22, 2012 7:44 pm
That bosch pump looks different to normal... Looks like there is a pipe coming out of the top.
You will also want to keep your old fuel filter and housing... unless you want to splice diesel lines
2 x 2006 Mk7s
Postby ake » Sat Dec 22, 2012 8:55 pm
MinorMatt wrote:That bosch pump looks different to normal... Looks like there is a pipe coming out of the top.
I think you are seeing the link for the throttle butterfly ;)
