Temprature sender help please
Postby Lmalone » Tue Jan 01, 2013 2:43 pm
My temprature gage doesn't work so rang for they sold me this part http://instagr.am/p/T8XIiMiobJ/
Now they told me it goes next to rocket cover on right hand side but it doesn't the one on mine looks like this http://instagr.am/p/T8Xf-XiobQ/
Or am I being thick :/
Lmalone
Re: Temprature sender help please
Postby liteace » Tue Jan 01, 2013 3:42 pm
If it wrong change it for the correct one
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby taz666 » Tue Jan 01, 2013 10:09 pm
the cht or cylinder head temp sensor is located on the right hand side of the engine below the black oil catch tank which you will have to remove to see it just above the top of the gearbox bell housing between the 2 top bell housing bolts
taz666
Ford Technician
Postby Lmalone » Tue Jan 01, 2013 10:34 pm
taz666 wrote:the cht or cylinder head temp sensor is located on the right hand side of the engine below the black oil catch tank which you will have to remove to see it just above the top of the gearbox bell housing between the 2 top bell housing bolts
I stripped it down and couldn't get it out as none of my tools would fit! Is that defo the correct one for temprature gauge ?
Lmalone
Postby Altransit » Wed Jan 02, 2013 1:41 pm
I'm pretty sure that the CHT sensor only feeds data to the ECU, the sensor for the gauge is different :?
Postby Altransit » Wed Jan 02, 2013 1:50 pm
Altransit wrote:I'm pretty sure that the CHT sensor only feeds data to the ECU, the sensor for the gauge is different :?
........................... although I can't seem to find a temperature gauge sensor anywhere else, so it must be the same one :? :oops:
Postby winterheating » Wed Jan 02, 2013 2:12 pm
The first pic is the cht.
The 2nd pick is tha air intake temperature sensor normally found on earlier mk6 2.4 egr valves with separate MAP sensor.
The PCM uses the cht readings for itself and sends a signal to the cluster, so the cluster gauge isn't as precise immediately.
winterheating
Postby winterheating » Wed Jan 02, 2013 2:15 pm
Normally have to cut the wire at the top and use a 15mm socket, or if you may need to use it again will have to cut a slot on a 15mm ring spanner.
winterheating
Postby Altransit » Wed Jan 02, 2013 2:45 pm
winterheating wrote: The PCM uses the cht readings for itself and sends a signal to the cluster, so the cluster gauge isn't as precise immediately.
Cheers WH, I couldn't understand why there was no separate water temp sensor for the gauge :oops: :roll:
