Ford Dab aerial part numbers ?
Postby blue estate » Wed Jan 02, 2013 10:35 pm
As title says , does any one know the part numbers for the dab aerial for a high top ?
blue estate
Re: Ford Dab aerial part numbers ?
Postby 75psT330lwb » Wed Jan 02, 2013 10:38 pm
look in the "what did u do to ur mk6/7" topic as someone(cant remember who) has just put a dab radio in their van so they might know as it was mentioned in there mate :)
Custom Ecoblue
75psT330lwb
Postby 75psT330lwb » Wed Jan 02, 2013 10:40 pm
just looking now but cant find it :? ignore me :roll: was in the connect section so prob different part no.
Custom Ecoblue
75psT330lwb
Postby Mike » Wed Jan 02, 2013 10:43 pm
Some of the parts?
paul2012 wrote:Yes you can install the Sony gen2 DAB stereo in to a connect but will required Ford DAB Aerial
The following parts for the aerial are normally found in a Focus Mk2 with DAB stereo, BUT can be easily installed into a connect
Parts required:-
Ford Part No F1559268 Aerial Base
Ford Part No F1559265 Rod Assembly - Aerial mast
Ford Part No F1682844 Cable Extension - With DAB and FM aerial plug - to Radio
Ford Part No F1545793 Cable Assenbly - Aerial to A pillar connection
Estimated parts cost £85 +vat Installation is very easy & would take about 30min
Mike
Wind up merchant!
Postby blue estate » Wed Jan 02, 2013 10:45 pm
I will try th dealers with those part numbers as i have just looked a how to do it on a focus and the cable looks the same and is joined on A pilar
blue estate
Postby 75psT330lwb » Wed Jan 02, 2013 10:47 pm
damn, was on the right track though :lol:
Custom Ecoblue
75psT330lwb
Postby blue estate » Sat Jan 05, 2013 12:05 pm
Mike wrote:Some of the parts?
Parts required:-
I managed to buy them all for £86.11 inc vat and delivery from ford parts
blue estate
Postby ake » Sat Jan 05, 2013 12:15 pm
What dab radio are you fitting? The Ford / Sony one?
Postby blue estate » Sat Jan 05, 2013 12:27 pm
ake wrote:What dab radio are you fitting? The Ford / Sony one?
Yes :D as i am fed up with the clock on the dash and not having auto vol and the 1 hour function
blue estate
Re: Ford Dab aerial part numbers ? update
Postby blue estate » Sat Jan 12, 2013 2:17 pm
Just fitted the aerial and i can confirm it will fit a high top with lead to spare :D so should fit med and low roof as well
blue estate
Postby stephenferguson » Sat Jan 12, 2013 6:03 pm
Got any pics of the dab connector? Does this have both aerial and dab cables?
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby blue estate » Sat Jan 12, 2013 6:08 pm
stephenferguson wrote:Got any pics of the dab connector? Does this have both aerial and dab cables?
both connectors
dab fakra
aerial
blue estate
Postby stephenferguson » Sat Jan 12, 2013 7:43 pm
cheers mate. i would need a fakra adaptor if i was to connect up to my pioneer dab.
stephenferguson
Postby blue estate » Sat Jan 12, 2013 7:55 pm
stephenferguson wrote:cheers mate. i would need a fakra adaptor if i was to connect up to my pioneer dab.
Yes as the fakra is only for the ford sony radio
blue estate
Postby 213 » Sat Sep 28, 2013 3:43 pm
Hello,
for those of you that have the ford aerial and cables, if you have installed a Pioneer head unit, can you advise of the adapter you used - I assume a fakra male to SMB Female would be required but finding one of them is pretty tricky. I'm trying to connect the Fakra part of the cable to a pioneer x3500DAB so any advice would be gratefully received.
Thanks, 213
213
