Mk7 lights on dash (picture)
Postby CH1 » Thu Dec 27, 2012 7:09 pm
My mate's 08 plate Mk7 100 T350 been stood since last Saturday, I got in it today and it wouldn't start, it wasn't even turning over, not even clicking, then tryed it again and then it started but these lights remain on, ABS and ESP light, any ideas???
M1 Tyres
Mobile Tyre Fitting Service
Covering the North East
http://www.m1-tyres.co.uk
Currently running:
Mk5 swb 80 with twin SLDs
Mk7 110ps T300 fwd pickup
Mk7 125ps T350 lwb Euro5
CH1
Re: Mk7 lights on dash (picture)
Postby ake » Thu Dec 27, 2012 7:11 pm
I reckon your front battery may be dying
Postby blue estate » Thu Dec 27, 2012 7:43 pm
ake wrote:I reckon your front battery may be dying
+1
blue estate
Postby CH1 » Thu Dec 27, 2012 7:58 pm
Cheers guys, I will tell him tomorrow :D
M1 Tyres
Currently running:
CH1
Postby t2myd » Thu Dec 27, 2012 9:30 pm
My dad had same lights on his ,turned out it was the abs module :(
Transit vantastic !!!!!!
t2myd
Postby CH1 » Thu Dec 27, 2012 10:20 pm
t2myd wrote:My dad had same lights on his ,turned out it was the abs module :(
How much did that cost to replace???
M1 Tyres
Currently running:
CH1
Postby ake » Thu Dec 27, 2012 10:22 pm
Stop panicking, get battery's checked first, low voltage will cause the lights to come on because the module shuts down.
Another common cause of the lights coming on is when vermin chew the wires that run below the floor.
Postby CH1 » Thu Dec 27, 2012 11:46 pm
ake wrote:Stop panicking
Not my van to panic about :lol: I will check the battery tomorrow
M1 Tyres
Currently running:
CH1
Postby t2myd » Fri Dec 28, 2012 1:39 am
Wernt that much ford wanted £4500 to replace abs pump,engine wiring loom , and whilst it was in there compound it got broken in to
t2myd
Postby CH1 » Fri Dec 28, 2012 6:01 pm
Today's update, didn't have the time or equipment to check battery this morning, van fired up no problem with abs and ESP light still on, also the low brake pad warning light came on aswell (all brake pads changed less than 2k ago by me). Drove it about 25 miles and stopped it for about 10 minutes, fire back up fine but battery light stopped on, still ran fine so just set off back, just got on the motorway and the temperature gauge shot right to the top, pulled it on the hard sholder and stoped it will water pissing out of somewhere, it's been recovered to my local garage to investigate. Think I am having a blue astate week :lol:
M1 Tyres
Currently running:
CH1
Postby CH1 » Thu Jan 03, 2013 7:21 pm
Turned out to be crank pulley, rubber is braking up causing the outer part of the pulley to stand still hense the belt not turning alternator, water pump etc, changing it tomorrow
M1 Tyres
Currently running:
CH1
Postby blue estate » Thu Jan 03, 2013 7:31 pm
CH1 wrote:Turned out to be crank pulley, rubber is braking up causing the outer part of the pulley to stand still hense the belt not turning alternator, water pump etc, changing it tomorrow
you need 15mm socket and breaker bar
blue estate
Postby CH1 » Thu Jan 03, 2013 7:50 pm
This happened to you didnt it ???? I am going to take the front of the van off, grill, radiator etc, is that the easiest way to do it ???
M1 Tyres
Currently running:
CH1
Postby blue estate » Thu Jan 03, 2013 8:07 pm
Don't need to :wink: there's enough clearance just as it's 3 thin bolts not 1 thick one
blue estate
Postby CH1 » Thu Jan 03, 2013 8:40 pm
blue estate wrote:Don't need to there's enough clearance just as it's 3 thin bolts not 1 thick one
Cheers for that blue, saved me a lot of graft, I will let you know how I get on tomorrow
M1 Tyres
Currently running:
CH1
