Radio Codes
Re: transit radio code
Postby Mickeyevo » Tue Jan 08, 2013 1:32 pm
[code][/code]Hi all, had same problem, van went in to get service and new battery now no radio,
Can any body help?
It's a 4000rds, serial number m364056
Mickeyevo
Re: connect radio code
Postby fireblade28 » Tue Jan 08, 2013 7:19 pm
try 4721
fireblade28
Re: Radio Codes
Postby karl » Wed Jan 09, 2013 3:14 pm
I have software for many kinds off radios blunket ,ford ,etc
Be glad to be assitence
karl
Tranny Lover!!!
Re: Radio Codes
Postby Highlander250469 » Wed Jan 09, 2013 4:31 pm
ats90210 wrote:thankyou! one other question,.... when i enter the code and press 5 after it just turns off and on again and goes back to the code screen.. any ideas? it was working fine before i took it out so cant see what the problem could be..
Double check your serial number, sounds like its entering wrong code
Motorman gave you 8758 which is correct for M236837 so either serial number is wrong or it has been reprogrammed in the past with a different code.
Highlander250469
Re: Radio Codes
Postby karl » Wed Jan 09, 2013 4:57 pm
Mines coming up with the same code 8758 !!!
karl
Tranny Lover!!!
Re: Radio Codes
Postby karl » Wed Jan 09, 2013 5:00 pm
I can get codes for the c and l series witch are old types !! A think
karl
Tranny Lover!!!
Re: Radio Codes
Postby husheechee » Mon Jan 14, 2013 1:14 pm
Hi,im new to the forum and need a radio code,the serial number is vo88366,many thanks
Husheechee
husheechee
radio code
Postby folthik » Mon Jan 14, 2013 3:02 pm
does anyone know the radio code for radio serial number V058651,van reg mf570tl?
cheers. :)
folthik
Re: radio code
Postby Altransit » Mon Jan 14, 2013 3:53 pm
husheechee wrote:Hi,im new to the forum and need a radio code,the serial number is vo88366,many thanks
Husheechee
folthik wrote:does anyone know the radio code for radio serial number V058651,van reg mf570tl?
cheers. :)
Read the first post in this thread :|
Re: Radio Codes
Postby folthik » Mon Jan 14, 2013 4:15 pm
Ps the part no is 6c1t-18c815-aj. Cheers.
folthik
Re: Radio Codes
Postby Highlander250469 » Mon Jan 14, 2013 4:23 pm
folthik wrote:Ps the part no is 6c1t-18c815-aj. Cheers.
Highlander250469
Re: Radio Codes
Postby bryer » Tue Jan 15, 2013 10:25 pm
Can anyone help me I need a code form my ford 6000 cd player ser No M021090
Many thanks I'm advance.
bryer
Re: Radio Codes
Postby Highlander250469 » Wed Jan 16, 2013 10:07 am
bryer wrote:Can anyone help me I need a code form my ford 6000 cd player ser No M021090
9195
Highlander250469
Mk 5 Transit radio code
Postby cbtransit » Wed Jan 16, 2013 4:25 pm
Hi can anyone source the radio code from serial number m127236
cbtransit
Re: Mk 5 Transit radio code
Postby g-man » Wed Jan 16, 2013 5:41 pm
try 2850
g-man
