I may not fit the power steering straight away thou
makes sence to merover wrote:It might be an idea to make up a specer to go between the downpipes and the manifold and weld a bracket to that, then bolt it up to the engine block at the bottom, creating a sort of cantelever effectThat will take the strain off your extensions pretty much altogether, then you only need to worry about lateral strain rather than vertical.
It made sense to me when I thought of it anyway, not sure it came over very well though![]()
Rover.
