help,help,helpPetFt@aol.com wrote:Cluster lights will come on and flash and will not stop till i disconnect the battery, take battery lead off and leave for an hour or so all is ok, until i drive sometimes an hour or so then it goes haywire again, clicking from relay under passengers feet,removed and clicking noise stops, but cluster still flashing, no intermittent wipers and interior light flashes when switched on, rev counter, speedo, fuel and temp all stick where they were when fault occurs
Brains Mk6 transit wrote:Is the battery in good condition
Mylee wrote:Check the smart charge lead. Triangular plug from the alternator, wires run along the rad under the battery and off towards the ecu. Comman fault that the wires break, replacement loom is available from your stealer for about £20
PetFt@aol.com wrote:Brains Mk6 transit wrote:Is the battery in good condition
Yes battery showed 16v on tickover and 12 with engine off
PetFt@aol.com wrote:Thanks guys, auto elect coming tomm will let you know how i get on
