Mk1 Bonnet removal
Mk1 Bonnet removal
Postby Southerner » Wed Sep 07, 2005 1:17 pm
Hi - I'm going to need to reseat the bonnet on my mk1 diesel minibus, is there anything I should know about doing this, I've had a quick look at it and there seems to be 2 bolts either side? For those of you that have done this before is there anything I should watch out for? Day off tomorrow, kids in playschool, I'm hoping to get alot done. Thanks in advance for your help. Andy.
Southerner
Postby madmark » Wed Sep 07, 2005 8:00 pm
mate when you say reseat what do you mean????? adjustment can be made by loosening off the bolts (4) :)
Postby Southerner » Wed Sep 07, 2005 8:46 pm
Thanks Mark, I need to bring it forward just a little to stop it scraping on the panel in front of the windscreen, if I can get away with just adjusting it I think that'll be one, Cheers.
Southerner
bonnet
Postby midniteclassix » Wed Sep 07, 2005 11:57 pm
i mark them first with tipex then i know were i started from any if all goes wrong i can go back to the start
old ford never die THEY JUST RUST AND FALL APART
midniteclassix
Postby Southerner » Fri Sep 09, 2005 9:40 am
Good tip with the tipex, well worth doing as it took a couple of goes to get right. Thanks, Andy.
Southerner
ajusting that bonnet
Postby john leeman » Fri Sep 09, 2005 10:03 am
once ajusted, don't forget the bonnet lock pin may be out of place too, this may need ajusting too. loosen the big locking nut where it screws into the bonnet its self, align before you shut the bonnet down, grease the pin too. good luck.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby Southerner » Sun Sep 11, 2005 8:35 pm
Thanks John, the pin was out to start with - so much so the bonnet popped twice whilst driving it home, no catch meant it flew right up to windscreen driving at 50mph. Not a big problem except the windscreen wiper on the nearside put a large dent into it. Grrr. Realigning the bonnet got the pin better as well but I'll double check its right on. I will grease it though as I didn't do that. Cheers, Andy.
Southerner
