mobilevanman wrote:well jealous i want that bar on my mk6 looking good though
All eyes on you then if it goes missing
robbie.cee wrote:Niiiiiicevery nice
vanmanloki wrote:the van is looking sweeeet, loving the A bar
vanmanloki wrote:Hi Ron, what was it like to replace your centre prop shaft bearing, I think mine has gone
robbie.cee wrote:yes i used fresh veg oil @£3 per 3l. add about 200ml 2 stroke oil per tankful, or more it wont hurt..
get spare fuel filters first m8 the veg will clear the sh*t from the tank into the filter!
RonTransitmk5 wrote:robbie.cee wrote:yes i used fresh veg oil @£3 per 3l. add about 200ml 2 stroke oil per tankful, or more it wont hurt..
Thanks Robbie, got 2 spare filters already, lol.
Will only use clean fresh veg oil, for now, lol
Got 3x spare fuel filters already m8, the veg oil will clear the sh*t from the tank into the filter!
RonTransitmk5 wrote:vanmanloki wrote:Hi Ron, what was it like to replace your centre prop shaft bearing, I think mine has gone
Really easy, just took the front half of the prop off & had to get the wife to hold prop in order to put the new bearing on as you need 3 hands![]()
Just make sure you put the LOCKWASHER back on correctly or the prop will fall off,as it did on mine, luckily I was only in 2nd gear so managed to stop & got the AA to replay it back home
Complete job took about 30 mins
RonTransitmk5 wrote:Trying very hard to get a towbar fitted at the mow so I can bring my boys to North Weald.
Stop![]()
Now
Where have I gone wrong? this fitting just does not look right.
maciejd wrote:RonTransitmk5 wrote:Trying very hard to get a towbar fitted at the mow so I can bring my boys to North Weald.
Stop![]()
Now
It just depends on what you want to achive![]()
I belive that couple of meters more of such tow bar extension and you might be really close to this:![]()
Or maybe that's the plan:
Both of them might be spectacular![]()
