The Big purple people Eater
Re: The Big purple people Eater
Postby robbie.cee » Tue Apr 02, 2013 11:23 pm
emmas nan is from there, Roscilly (?) bay excuse spelling ! :D
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby gruntyv8 » Sat Apr 06, 2013 8:36 pm
Gower was great :)
Robbie, i did think about chimney flap as i have fitted them on other stoves i built. I was advised against it as it could cause CO build up. I think though as i have a CO alarm i will fit one when i reduce the flue size as i rerally need to keep the fire going over night as its bloody cold when i get up for work atm.
Differnet subject :)
fuel and power...
20/23 MPG? sound about right?
on Mway i was down to 45mph in places :/ I have been told this is right but surely not ? i would expect a purpose built load lugger to handle a reasonable speed.
cheers in advance :)
gruntyv8
Postby AK » Sat Apr 06, 2013 11:38 pm
Speed and power is about right for a mk5 luton, my mk3 luton was the same slow slow slow
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby gruntyv8 » Sun Apr 07, 2013 12:20 am
Might need s newer chassis cab :/
Didnt feel safe on tbe mway
gruntyv8
Postby bezzabsa » Mon Apr 08, 2013 8:33 pm
look at the frontal aspect....like pushing a house LOL..try and cut the front down to an angle, may help!!
Driving a Transit estate...Mondeo 130 Tdci 2002 ;)
Yam Yam from yamyam land ayit ??
Bostin' ay it?
bezzabsa
Postby robbie.cee » Tue Apr 09, 2013 6:17 pm
...and double check all the bushes, linkages etc as might not just be the drag/wind you felt!! :wink:
Had
MAKE IT FIT
robbie.cee
Postby gruntyv8 » Fri Oct 31, 2014 7:25 pm
in need of updates :)
finally sanded kitchen doors..
The 2 seater sofa was nice for me but we are now a couple and using the van for festivals and weeks away so I decided a U shaped seating area would be more practical,
which meant moving the logburner.
latest little project removing the rollershutter and fitting a solid awning/door
I need to sort out gas struts to hold it up but it works for now :)
will dig out some more pics later..
gruntyv8
Postby RustWidow » Fri Oct 31, 2014 10:56 pm
Well done, hope you recover from your op soon
RustWidow
Postby Kedishen » Sun Nov 02, 2014 12:53 am
those cupboard doors are wicked mate. Bit of varnish perhaps for that warm wood feeling :D
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby robbie.cee » Sun Nov 02, 2014 10:50 am
what a truely stunning job. love the purple and that interior is fkn awesome pardon my french!
well done mate!!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Nov 05, 2014 11:33 am
just a thought, but If ypu ran a copper pipe thru burner amd use a Rad and heating pump, co7ld make a back boiler set up so burner also heats rad up via hot pipe amd small pump or any central heating pump
Had
MAKE IT FIT
robbie.cee
also diff ratio can be changed for better motorway mpg
Had
MAKE IT FIT
robbie.cee
