NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Sun Apr 07, 2013 7:55 pm
Here are the wiring connections & locations for fitting the 2009 onwards dash with switches & modules into a 2003-2006 connect.
(GEM Module, Hazard & indicator switches, Front wiper/wash, Air Recirculation switch etc)
NOTE - When fitting GEM module remove your old central locking module as GEM module operates central locking, if not removed then it will conflict with the newly installed GEM module !)
CENTRAL LOCKING WITH DEAD LOCKING
GEM IPL2 WH/BK UNLOCK MOTOR FRONT DOORS - C451 PIN 8 WH/BK
GEM BL11 BK/GN UNLOCK SWITCH FRONT RH DOOR C452 PIN 14 BK/GN
GEM BL12 BK/BU SET SWITCH FRONT DOORS - C452 PIN 12 BK/BU
GEM BL18 BK/YE AJAR SWITCH FRONT LEFT - C452 PIN 16 BK/YE
GEM BL19 BK/BU AJAR SWITCH FRONT RIGHT - C452 PIN 11 BK/BU
GEM BR10 BK/OG LOCK SWITCH FRONT DOORS - C452 PIN 15 BK/OG
GEM BR8 BK/WH RESET SWITCH FRONT DOORS - C452 PIN 4 BK/WH
GEM BR21 BK/WH RESET SWITCH REAR DOOR - C451 PIN 10 BK/WH
GEM BR18 BK/OG LOCK SWITCH REAR DOOR - C452 PIN 13 BK/OG
GEM BL17 BK/RD AJAR SWITCH REAR DOOR - C452 PIN 2 BK/RD
GEM BL13 BK/BU SET SWITCH REAR DOOR - C452 PIN 1 BK/BU
GEM BR6 YE DEADLOCK LEFT SIDE - C41 PIN 18 YE
GEM BR7 YE DEADLOCK RIGHT SIDE - C43 PIN 18 YE
GEM BR5 WH/GN REAR DOOR UNLOCK C52 PIN 8 WH/GN (ADD REAR DOOR UNLOCK RELAY !)
GEM EN1 YE/BK LOCK ALL DOORS - C451 PIN 3 YE/BK
GEM EN2 OG/WH VBAT LOCKING - C452 PIN 5 OG/WH F63 20A
GEM EN3 BK GND - C451 PIN 6 BK
GEM IPL10 GN/OG IGNITION - C452 PIN 7 GN/WH F48 7.5A
GEM BL16 GY EXT ANTENNA - C452 PIN 9 GY
GEM IPR13 BK/OG RADIO SENSE - C451 PIN 13 BK/OG
LIGHTS
GEM BL4 OG VBAT TURN SIGNAL - C451 PIN 2 OG/WH F61 15A
GEM BL2 BU REAR LEFT INDICATOR -C61A PIN 13 BU
GEM BL3 BU/WH FRONT LEFT INDICATOR - C451 PIN 9 BU
GEM BL1 BU/RD REAR RIGHT INDICATIOR - C61A PIN 14 BU/RD
GEM BL6 BU/RD FRONT RIGHT INDICATOR - C451 PIN 1 BU
GEM IPR18 BU - STALK TURN LEFT SWITCH PIN 6
GEM IPR17 BU/RD - STALK TURN RIGHT SWITCH PIN 7
2009> INSTRUMENT CLUSTER J1-3 BK/OG - STALK MAIN BEAM SWITCH PIN 8 (ADD LOW BEAM INTERUPT RELAY !)
2009> INSTRUMENT CLUSTER J1-2 BK/BU - STALK PASS/FLASH SWITCH PIN 9
STALK SWITCH PIN 10 BK/GN - GND
GEM BL7 OG/BK VBAT EXT LIGHTING - C320 11 PIN OG/BK
GEM BL5 OG/GN SIDE LIGHTS - C320 13 PIN OG/YE
GEM BL21 BK/BU INTERIOR LIGHTS - C813 PIN 19 BK/BU (INTERIOR LIGHT RELAY)
GEM EN6 OG/BU BATT SAVER - C14 PIN 7 OG/BU DOME LIGHTS
GEM IPR16 BK/OG - PIN 6 HAZARD SWITCH
ILLUMINATION OG/GN - PIN 5 HAZARD SWITCH
GND BK/OG - PIN 4 HAZARD SWITCH
RECIRCULATION SWITCH/MOTOR
GEM BR20 OG/GN VBAT RECIRC - C380 PIN 8 OG F59 7.5A
GEM BR15 WH/BU RECIRC MOTOR + - C375 PIN 4 WH/BU
GEM BR16 YE/BU RECIRC MOTOR - C375 PIN 2 YE/BU
GEM BR17 GN/YE RECIRC TELLTALE - RECIRC SWITCH PIN 1
2009> INSTRUMENT CLUSTER J1 PIN 18 GN/BK - RECIRC SWITCH PIN 6
C380 PIN 2 OG/GN ILLUMINATION - RECIRC SWITCH PIN 3
C380 PIN 12 BK/OG GND - RECIRC SWITCH PIN 2 & 5
FRONT WIPER/WASH
GEM IPR5 GN/RD FRONT WIPER IGNITION - C17 PIN 5 GN/RD
GEM IPR3 YE/BK FRONT WIPER WASH - WIPER SWITCH PIN 1
GEM BR23 BK/RD FRONT WIPER HIGH SPEED - WIPER SWITCH PIN 2
BK GND - WIPER SWITCH PIN 3
GEM IPR4 WH/BK REAR WIPER WASH - WIPER SWITCH PIN 4
C809 PIN 25 BK/WH - WIPER SWITCH PIN 6
GEM BL20 WH/RD WIPER DATA 1 - WIPER SWITCH PIN 7
BK GND - WIPER SWITCH PIN 8
GEM IPR7 WH/BU WIPER DATA 2 - WIPER SWITCH PIN 9
GEM IPR14 WH/GN WIPER DATA 3 - WIPER SWITCH PIN 11
GEM BL9 BK WIPER INTERVAL/AUTO - WIPER SWITCH PIN 12
GEM IPL4 WH/BU WIPER PRK POSITION - C14 PIN 2 WH/BU (CUT)
GEM IPL3 WH/BK WIPER HIGH - C441 PIN 8 WH/BK
GEM IPR1 WH/BU WIPER LOW - C14 PIN 2 WH/BU RELAY
C441 PIN 7 WH/BK & PIN 9 WH/GN (CONNECT TOGETHER !)
Wiring details for the 2009 onwards Instrument cluster will follow soon :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Sat Apr 13, 2013 4:13 pm
Started to assemble my new front bumper, now it has been painted. :D
paul2012
Postby paul2012 » Sat Apr 13, 2013 5:13 pm
Was was planning on fitting the new front bumper today, but I have not got the mounting screws for the Fog lights :(
Which were a bargain at £25 for the pair complete with bulbs :D
paul2012
Postby Mylee » Sat Apr 13, 2013 5:41 pm
Everything you buy is a bargain? Why not share this great bargain shop you seem to know?
Mylee
Postby paul2012 » Sat Apr 13, 2013 6:03 pm
Mylee wrote:Everything you buy is a bargain? Why not share this great bargain shop you seem to know?
Unfortunately theres not just one place I get parts, It pays to shop around to get the best deal :wink:
The foglights came from ebay, seller purchased the wrong ones :roll: hence why they were cheap :D
Even the lower bumper grille was £19 New from ebay, Top Grille (Platinum) Genuine Ford Part no F5144239 £55 from Ford (Trade)
paul2012
Postby paul2012 » Mon Apr 15, 2013 5:56 pm
Fitted my new front bumper :D
Just need to sort out the bonnet now.
paul2012
Postby Mylee » Mon Apr 15, 2013 7:20 pm
Looks like the wrong shade of white to me :(
Mylee
Postby g-man » Mon Apr 15, 2013 7:23 pm
to be fair.......dose'nt look to bad
g-man
Postby paul2012 » Mon Apr 15, 2013 7:29 pm
Mylee wrote:Looks like the wrong shade of white to me :(
:shock: :lol: :lol:
It is the correct shade - I took the old N/S rear door down to paint suppliers to get the proper colour match :wink:
mind you, the van is covered in dust etc at the moment.
paul2012
Postby Meganx » Mon Apr 15, 2013 9:17 pm
paul2012 wrote:Fitted my new front bumper :D
Cracking job m8 :-)
Meganx
Postby paul2012 » Tue Apr 16, 2013 8:07 pm
Got new badges for the rear doors today :wink:
paul2012
Postby oldyellar » Wed Apr 17, 2013 9:00 pm
van is takening shape looks good 8)
oldyellar
Postby paul2012 » Thu Apr 18, 2013 1:59 pm
g-man wrote:to be fair.......dose'nt look to bad
zaxis210 wrote:great job you doing there m8 will be a good van
Meganx wrote: Cracking job m8 :-)
oldyellar wrote:van is takening shape looks good 8)
Thanks guys,
Still more work to do yet, but slowly getting there :wink:
paul2012
Postby paul2012 » Thu Apr 18, 2013 6:22 pm
Few more minor jobs done.
N/S rear door badges fitted
Bumper towing eye covers painted today & fitted, just need to get bonnet sorted first before fitting the trim.
Ran a test on the instrument cluster, Now require ext air temp sensor :?
paul2012
Postby paul2012 » Fri Apr 19, 2013 12:22 pm
Fitted 2009 onwards new rear lights today.
paul2012
