Bring Duetto back to life (hopefully)
Postby pagan86 » Fri Apr 12, 2013 9:26 pm
pagan86
Re: Bring Duetto back to life (hopefully)
Postby pagan86 » Tue Apr 16, 2013 7:54 pm
Santas came early, just need time to get at it now
pagan86
Postby blue estate » Tue Apr 16, 2013 7:57 pm
Was santa called Tim and comes from kent ? :lol:
You've got your work cut out :shock: but considering a good one could still fetch 10k
blue estate
Postby pagan86 » Tue Apr 16, 2013 8:03 pm
I got the stuff through my work mate (work in a garage, so got it trade price), hopefully start taking old floor pan out tomorrow, might take a week off work soon and try get some done, all fun and games
pagan86
Postby pagan86 » Thu Apr 18, 2013 9:28 pm
Cupboard removed, more ply wood out (nightmare to get out, what ever they stuck it down with worked) and carpet cut out, got enough stripped out now to start taking floor pan out
Join for floor pan, eventually found it :)
Took a weeks holiday next week to get on with it :D
pagan86
Postby pagan86 » Fri Apr 19, 2013 9:28 pm
Started taking floor pan out tonight, more rotten than I thought, get spot weld drill out tomorrow try get rest out and rear cross member :(
Image Image
pagan86
Postby pagan86 » Sat Apr 20, 2013 6:52 pm
Bit more done today, most floor pan out now (some job), recommend a 10mm spot weld bit instead of an 8, edges along outside of chassis rails gona need replaced and more rust found front spring hanger drivers side, these transits don't half rust
Image Image
Image Image
pagan86
Postby pagan86 » Mon Apr 22, 2013 7:03 pm
O/S Chassis rail welded up and new lip welded on
Image Image
Started on O/S front spring hanger and rear of sill
Image Image
pagan86
Postby pagan86 » Tue Apr 23, 2013 7:11 pm
N/S was was just as bad as O/S but that's them done, on to rear cross member and spring hangers tomorrow
pagan86
Postby pagan86 » Thu Apr 25, 2013 8:49 pm
Rear cross member removed, welded a temp piece of bar in to hold everything in place
New cross member in and a lick of red oxide
O/S and N/S spring hangers and new rear inner corners welded in
Welded new lip on N/S chassis leg
pagan86
Postby BigMonty » Thu Apr 25, 2013 9:27 pm
NOW that is progress !
Keep the pics coming , I am really enjoying this thread.
8)
BigMonty
Postby pagan86 » Thu Apr 25, 2013 9:40 pm
Been on holiday this week mate so that's how Iv'e got so much done, back to work on Monday :(
pagan86
Postby pagan86 » Fri Apr 26, 2013 8:16 pm
Spare wheel cross member back in one piece today (paint stiil wet)
pagan86
Postby pagan86 » Sat Apr 27, 2013 8:12 pm
Axle and springs rubbed down ( couple hours chipping rust of the axle, hope she doesn't start leaking) and 2 coats of red oxide
pagan86
Postby BigMonty » Sat Apr 27, 2013 8:24 pm
Great work again. I would have sh*t my pants !
Need the thread title changing, and get rid of that " hopefully " bit.
Big thumbs up !!!!
BigMonty
