ps..For got to say. My Transit is 1989. 2.5. Mk3..I think..
bambi mk 1 wrote:You do not have to remove the pump but it is tricky to do in place for a first timer.If you pull off the plastic rod and take out the 13 and 19mm bolt and nut at the bottom of the housing and take the advance housing off gently.The leak will be from the opposite side where the piston slides.It is a special seal and replace the piston also.Use cav parts only .Your local diesel engineer should be able to supply the parts.Get a gasket set for pump the seal will be in the set but not the piston.Change little spring in there also and watch carefully where everything goes including the shim or shims inside the piston.When replacing use a rubber band to hold the piston in till you fit it back on to the pump.
BlueBikerNut wrote:I Hope This is done right. Never tried putting picture on site before.Admin if its wrong can you sort it..or tell me where I gone wrong please..
bambi mk 1 wrote:Fred I am not always right but I am never wrong . Take off the housing its leaking from the opposite side and running along the bottom of the pump.Done loads of them .
bambi mk 1 wrote:Fred I posted info earlier. If its to much for you try your diesel shop as it wil only take a hour max.
BlueBikerNut wrote:bambi mk 1 wrote:Fred I posted info earlier. If its to much for you try your diesel shop as it wil only take a hour max.
now this on flebay https://www.ebay.co.uk/itm/171036780276&seller=&toolid=10018&66482099" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/171036780276
