Bring Duetto back to life (hopefully)
Re: Bring Duetto back to life
Postby pagan86 » Sat Apr 27, 2013 8:49 pm
Cheers mate, she slowly getting there, get the axle painted black tomorrow and put back in so I can jack up van and move blocks further back so can start repairing inner sills. Need them done so can weld arches and lower panels to them, shitting myself about doing body work, might try find someone to come give me a hand
pagan86
Re: Bring Duetto back to life (hopefully)
Postby n8rbos » Sat Apr 27, 2013 11:59 pm
Cracking job m8.
n8rbos
Postby pagan86 » Sun Apr 28, 2013 7:57 am
Cheers mate
pagan86
Postby pagan86 » Mon Apr 29, 2013 11:04 pm
Ronseal black hammered finish on the axle
Pulled bumpstrip off and half the van came with it,lol
pagan86
Postby robbie.cee » Mon Apr 29, 2013 11:53 pm
tis only a flesh wound compared to the graft you just put in!! bloody good show m8, van'll be mint once done!! 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby pagan86 » Tue Apr 30, 2013 9:24 pm
Started on o/s inner sill tonight at the rear, using 2 mm plate, surely it will last and its easier to weld to than 1mm, I tied it into the front spring hanger I welded up last week. Had to cut quite alot out to get to clean metal and the higher you go up the sill it ain't flush so alot of hammering to get metal touching so it can be welded, not easy welding etc lying on your back
Image Image
pagan86
Postby Mr RVM » Wed May 01, 2013 12:07 am
2mm plate everywhere underneath is the way forward :!: even if you left it bare it would last years, ive used it on the chassis and floor of my truck and it'll last longer than i will :!: :lol: :lol: :lol:
Mr RVM
Postby pagan86 » Wed May 01, 2013 7:40 am
Thats what iv'e used everywhere mate, used 1 mm before on jobs an few year down the line its rotten again
pagan86
Postby pagan86 » Wed May 01, 2013 10:49 pm
Inner sill nearly finished, cross member to repair still, 3 wee plates to make up for it
pagan86
Postby Mr RVM » Wed May 01, 2013 11:03 pm
Lookin good mate lookin good :!: :D :D :D
Mr RVM
Postby ake » Thu May 02, 2013 5:18 pm
Nice work :D
Postby pagan86 » Thu May 02, 2013 8:40 pm
Floor pan spotted in, still a bit work to tie it into arches and sides
pagan86
Postby robbie.cee » Tue May 07, 2013 9:12 pm
great work m8, what welder are you using ? :mrgreen:
Had
MAKE IT FIT
robbie.cee
Postby pagan86 » Wed May 08, 2013 6:25 pm
Just a mig mate, Lincoln, good welder! Not been at the transit since Sat, going to need to get back to it tomoz night, to a little
pagan86
Postby pagan86 » Thu May 23, 2013 9:59 pm
Bottom of arches repaired, floor finished and painted with some white paint left over from tractor wheels
In the wheel arch where the floor was welded onto arch
pagan86
