brake cylinders
brake cylinders
Postby gringo » Thu May 09, 2013 8:16 pm
does anyone know where i can find some rear brake cylinder kits ?? i would be interested in front kits as well but there arent urgent.....
otherwise where is there someone who stocks the complete cylinders....
it is for a twin wheeler campervan 1972
gringo
Re: brake cylinders
Postby mb4ever » Thu May 09, 2013 8:38 pm
mb4ever
Re: brake cylinders
Postby Ralph.9 » Thu May 09, 2013 8:52 pm
I have a pair of genuine rear cylinders for twin wheel MK1 £15 pair. Give me a call if your interested on 07940582374. Cheers Ralph
Ralph.9
Re: brake cylinders
Postby baconsdozen » Fri May 10, 2013 8:41 am
If it helps anyone else there is a firm called Nelsons who list brake rubbers etc for early transits as well as other old cars.
baconsdozen
Re: brake cylinders
Postby mb4ever » Fri May 10, 2013 11:29 am
baconsdozen wrote:If it helps anyone else there is a firm called Nelsons who list brake rubbers etc for early transits as well as other old cars.
Nelsons were mega-helpful last time I used them. :D
They gave me very good prices too. :D :D :D
Here's the addy again if you want to save it somewhere.
http://www.apnelson.co.uk/contacts.htm
mb4ever
Re: brake cylinders
Postby gringo » Mon May 13, 2013 11:14 am
thanks for the replys
what cwt would my 1972 2.0 petrol twin wheel camper be ??
gringo
Re: brake cylinders
Postby mb4ever » Mon May 13, 2013 11:51 am
gringo wrote:thanks for the replys
The model number will tell you what you need to know Gringo.
Or the VIN plate.
I suggest however that you measure the diameter of your old cylinders.
During 40 years, someone may have changed things around.
mb4ever
Re: brake cylinders
Postby Trinny » Mon May 13, 2013 3:38 pm
Don't forget, plently of Plus Gas on your brake nipples
Trinny
Re: brake cylinders
Postby mb4ever » Mon May 13, 2013 5:33 pm
Trinny wrote:Don't forget, plently of Plus Gas on your brake nipples
Good thinking Trinny, would you also recommend splashing some round the tube nut on the brake pipe?
mb4ever
Re: brake cylinders
Postby Trinny » Fri May 17, 2013 11:49 pm
Just check on the tin it's ok on for rubber
Trinny
Re: brake cylinders
Postby mb4ever » Sat May 18, 2013 10:42 am
Trinny wrote:Just check on the tin it's ok on for rubber
Good advice Trinny.
The tube nut is on the brake pipe about an inch from nipple, so well away from any rubber.
Tube nuts trap water if they aren't greased after assemby, which means the pipe can become very fragile.
Not unknown to have to replace pipes along the axle when you replace wheel cylinders.
Red rubber grease is probably the best grease to use around wheel cylinders.
It can be used under the ruber dust caps on brake cylinders, on nipples, and tube nuts.
It's compatible with normal brake fluid and brake rubber.
eBay listings
mb4ever
Re: brake cylinders
Postby Ellwood » Sun May 19, 2013 1:37 pm
My 1970 mk1 has 22.2 mm diameter cylinders on the front brakes. its got double back wheels and a dual braking system if thats any help to you.
Ellwood
Re: brake cylinders
Postby mb4ever » Sun May 19, 2013 2:03 pm
Ellwood wrote:My 1970 mk1 has 22.2 mm diameter cylinders on the front brakes. its got double back wheels and a dual braking system if thats any help to you.
If you contact Pete Chapman, I am sure he will be able to suppy new seals and a new dust caps Ellwood.
pete_chapman@nelsonstokes.com
It isn't much help towards knowing the ID of your rear cylinders though, as someone may have replaced the cylinders the factory fitted with a different size.
It's an easy way to tune brakes.
mb4ever
Return to Mk 1 & 2
