what injectors do I need and where can I get them??
Postby Maz » Fri May 10, 2013 11:47 am
Morning all,
I've got a lwb semi hightop minibus, not had it for long and recently the power has dropped massively :(
I'm not a mechanic but I am having to learn quite alot lol, luckily my brother is a mechanic :) (he doesnt get much time to help me out though as he's always working!)
I noticed one of the injectors had a loose cap and diesel was leaking out of it. Got my brother round and he said that there must have been a problem with this injector as at some point and someone had put ptfe tape at the bottom of the injector. Also the reason the cap has come loose is because presumably the last owner knackered the thread when screwing it back on.
The van is knocking on a bit now (w reg but still an awesome van) and I wondered whether it would be better to replace all the injectors rather than just the knackered one?
If I do replace them what should I go for and where is the best place to get them?
If it helps the vans reg is W549XKM
Thanks in advance for any help :)
Maz
Re: what injectors do I need and where can I get them??
Postby Maz » Fri May 10, 2013 5:11 pm
I found this on ebayhttp://www.ebay.co.uk/itm/Ford-Transit- ... 417314c9c4
Is it any good to me?
Maz
Postby karl » Fri May 10, 2013 8:06 pm
A think that's the one but am not to sure
Am sure someone will confirm soon
karl
Tranny Lover!!!
Postby MinorMatt » Sat May 11, 2013 10:04 am
He hasn't given all the part numbers - and you havent given all the details. That could be any one of 4 injectors
What power engine do you have fitted?
Postby karl » Sat May 11, 2013 10:47 am
here are his van details
Primary Features
Build Date: 27.04.1999
Vehicle Line: Transit 1995-2000
Cab Style: Bus (M2)
Series: 130
Engine: Diesel 2.5 (76PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.14
Emission: 97 EC LDT Requirements
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Windrush G-C
karl
Tranny Lover!!!
Postby MinorMatt » Sat May 11, 2013 12:03 pm
Ok you need 33706 injectors - from a 97 onwards bananna engine. That advert doesn't say what they are
Postby Maz » Sat May 11, 2013 8:17 pm
Thanks for the replies guys, I really appreciate the help :)
My next question is how easy is it to get hold of a set of them?
If I said it was the fuel return one that was knackered, would that make some sense?
I can get a pic of it if that would be easier?
Maz
Postby MinorMatt » Sat May 11, 2013 8:46 pm
The injectors are all the same...
Postby Maz » Sun May 12, 2013 4:08 pm
I've had a look on ebay for those injectors but havent had much luck - does anyone know where I can get some replacements?
Maz
Postby MinorMatt » Mon May 13, 2013 8:12 am
Do you want one or 4?
DieselHead123 can get brand new ones ;)
Postby Maz » Mon May 13, 2013 9:55 am
Hiya, well it's only the one thats knackered but depending on how much a set of 4 cost, I might replace the lot. At least then I'll know they'll all be working correctly and if needs be keep my old ones as spares in case I need them :)
Maz
Postby MinorMatt » Mon May 13, 2013 9:56 am
about £250 for the 4 IIRC correctly - but ask him! These are new ones not reconned ;)
Postby Maz » Mon May 13, 2013 10:08 am
MinorMatt wrote:about £250 for the 4 IIRC correctly - but ask him! These are new ones not reconned ;)
Woa, ummm maybe just the one for now then since there's a few other things needed for the van!
I'll pm him for a price :)
Thanks for the head up :) :)
Maz
Postby MinorMatt » Mon May 13, 2013 10:22 am
I might be able to get some 2nd hand ones (but only 3) and I won't know immediately...
Postby Maz » Mon May 13, 2013 11:41 am
I've pm'd dieselhead123 regarding the injectors so I'll wait to hear back from him :)
In the meantime if you could get those injectors how much would you be looking for them?
Do you know if theres a way of cleaning the injectors yourself or is it a specialist job?
Maz
