Would I benefit any by putting, 3 on the front and 5 on the back? I carry heavy tractor stuff sometimes and could do with a little upgrade
Joe
Di Jack Regan wrote:Can anyone tell me how many springs I should have on my MK1? As it has a 2.5 Di (don't know if it makes a difference) I have one leaf on the front and 3 on the back.
Would I benefit any by putting, 3 on the front and 5 on the back? I carry heavy tractor stuff sometimes and could do with a little upgrade![]()
Joe
Neil wrote:my mk 1 has 3 on the back and 1 on the front that's the norm ,,,,the single front was tempered for the weight and ive seen before on fitting a heavier di the front end sags a bit low as the early ones are for a perkins or v4 on my last mk 1 di I fitted a pair of fronts off a later mk 2 di to cure it or off a v6 will do,,, a firm called Rossendale road springs can give good advice on re tempering,,, on my mk 1 with the v8 in that has a 1970 s jacking kit fitted which gives about 740mm from floor to wing arch at the front
Neil wrote:I can only say what works from personal expieriancedo those weights include all the bolt on bits too or just the blocks
Di Jack Regan wrote:Neil/mb4ever, thanks for all the info. I'm afraid all the geometry and maths is going over my head![]()
I'll try and post a picture up later of what my MK1 looked like on my trip to France last month. My understanding was, that if I didn't want to have my arse kissing the tarmac with the 3 leafs I've got at the rear with a full load, surely adding another 2 leafs per side would give me the stance I want at the rear.
I ask, as I've seen a pair of NOS rear leafs, with 5 leafs, advertised as for MK1 up to 1976, and also NOS fronts with 3 leafs. Has the seller got it wrong, or are they maybe for the twin wheel LWB?
Joe
mb4ever wrote:Neil wrote:I can only say what works from personal expieriancedo those weights include all the bolt on bits too or just the blocks
The diesel certainly had all the bolt on bits Neil.
As far as I could work out, the petrols also had all the bolt on bits.
Neil wrote:mb4ever wrote:Neil wrote:also the perkins only had I battry no servo and a small rad as the v4 early on which model mk 1 had a 3 leaf front spring
davev6newman wrote:My Mk 2 V6 LWB camper has singles on the front and triples on the rear.
I did have a Mk1 V6 camper as well LWB and the springs had sagged at the back.
I had new springs made by a local firm to me, but the van always sat high at the back after that.
