belly wrote:I should've booked my 200 in with Dan when I collected it, I could've stayed up there one night and driven back with everything done
But could you have trusted those brakes ?
Dale1970 wrote:I have noticed that dudes on here are saying the 85 to 110ps as AA injectors & pump which the AA means low flow injectors on mine they are AB which is high flow so bit confusedIf they are high flow that's the reason my van is like a flying machine.
blue estate wrote:belly wrote:I should've booked my 200 in with Dan when I collected it, I could've stayed up there one night and driven back with everything done
But could you have trusted those brakes ?![]()
Rumble bee wrote:Dale1970 wrote:I have noticed that dudes on here are saying the 85 to 110ps as AA injectors & pump which the AA means low flow injectors on mine they are AB which is high flow so bit confusedIf they are high flow that's the reason my van is like a flying machine.
Where abouts is it labeled what they are![]()
Chris
martynx wrote:Yes , part number is engraved into side of injector ( need to remove them to view it ) -last 2 digits, ie- AA AB AC etc are the so called low flow units fitted to 85, 100, 110 then 115 & above have BA, BB, BC etc the higher ones.., the last letter being a version / revision identifier.
t2myd wrote:martynx wrote:Yes , part number is engraved into side of injector ( need to remove them to view it ) -last 2 digits, ie- AA AB AC etc are the so called low flow units fitted to 85, 100, 110 then 115 & above have BA, BB, BC etc the higher ones.., the last letter being a version / revision identifier.
How are you at doing the 110,s
now Martyn ?
Also the 2.4 140 ? and as Eggski said i am willing to be a guinea pigEggski wrote:Have you managed to sort anything on the RWD 2.4 115s yet?
If you need to borrow mine for dyno then I'm sure there could be an arrangement!
martynx wrote:140 2400 Yes Pete but not dyno'd yet, 115 2400 not done yet !! its next though.. and a tipper will fit on the dyno's i use..will be in touch on that one Eggs
blue estate wrote:Just got home after a great driveMartyn has delivered the goods again
I had a pcm , pump pilot learn and Remap
loot34 wrote:blue estate wrote:Just got home after a great driveMartyn has delivered the goods again
so what did you get? and do you feel the difference? have you felt any improvement from a cold start? I'm sure I know the answer but having a 140 I'm quite interested.
