Mk5 transit mods, bits, tips and tricks
Postby Maz » Tue May 14, 2013 2:03 pm
Hi all,
I've got a W reg, lwb, semi hi-top transit minibus non turbo 2.5 diesel
I'm wanting to get a bit more power and performance on it (also needs a new injector but thats another thread...)
I've seen the egr and fuel pump mod http://fordtransit.org/articles/engine/ ... wer-mk5-di
Theres an egr blanking plate on ebay http://item.mobileweb.ebay.co.uk/viewit ... 9891240246
It just saves a bit of time and hassle if I buy one rather than make one
I've seen something about a leak off mod - can someone explain it to me please or point me in the right direction on where to get a good description of what it is?
I'm getting s service kit too
Then theres the 2 stroke in with the diesel - what does it do? I'd really like to know about this and how it works, so I'd really appreciate any advice on that one
Any other advice tips on these vans I'd love to hear too
Thanks :D
Maz
Re: Mk5 transit mods, bits, tips and tricks
Postby karl » Tue May 14, 2013 4:28 pm
2 stroke actes like a cleaning fluid for the injectors stop the tips of the injectors carboning up :D
for the egr plate id get one with slits in so you can just slide it place or just cut them in when you get it
karl
Tranny Lover!!!
Postby angeleye » Tue May 14, 2013 4:45 pm
two stroke acts as a lubrication for the fuel pump,
heres the leak off mod leak just click link
viewtopic.php?f=4&t=37978&start=15#p350602
angeleye
Postby Maz » Tue May 14, 2013 7:03 pm
So how much 2 stroke am I looking to add when fill up? Bearing in mind that I usually put in about £30ish a week
And what type of 2 stroke do I use? I use stihl ultra 2 stroke oil for my tools at work http://www.amazon.co.uk/gp/aw/d/B007TJK ... 276&sr=8-1
Would that be suitable?
Is the leak off mod worth doing?
Karl is it just for convenience to have a blanking plate that slides in place or is there another reason, just wanna know really :)
Maz
Postby Maz » Thu May 16, 2013 9:45 pm
Added a bit of 2 stroke while filling up - not alot though as I have no idea how much you add to the diesel - anyone know how much to add??
Maz
Postby Altransit » Thu May 16, 2013 9:48 pm
I put 300ml in a full tank of diesel 8)
Postby Maz » Thu May 16, 2013 9:53 pm
Altransit wrote:I put 300ml in a full tank of diesel 8)
Ahh okay, thanks for that :)
Do you know if that stihl 2 stroke I linked to would be okay to use or is any 2 stroke fine to stick in the tank?
Maz
Postby Altransit » Thu May 16, 2013 10:06 pm
Not much in the way of details to go on with that, but it looks to be stupidly expensive :shock:
So long as it's 2 stroke self mixing oil, designed to mix with petrol to run a 2 stroke piston engine, then anything will do the job IMO 8)
Postby joinerman » Thu May 16, 2013 10:09 pm
I use asda's finest. £5 a litre, i just slug about 1 1/2 inches out the bottle to £20 of derv, you won't do any damage if you put in more.
joinerman
Postby Maz » Thu May 16, 2013 10:29 pm
Altransit wrote:Not much in the way of details to go on with that, but it looks to be stupidly expensive :shock:
It is stupidly expensive but I get it on the work account - crazy money for 2 stroke eh?!
Maz
Postby awdriver96 » Fri May 17, 2013 12:52 pm
You want the plain mineral 2stroke oil, not the synthetic stuff as it doesnt work as well and mineral is far cheaper to buy, I get a gallon for £9+ pennies at the local factors. I put around 300-350ml ina tank full but abit more wont do any harm, it takes a while for the difference to show, but it makes mine run like a sewing machine instead of a bag of spanners. :lol:
mt
awdriver96
