sliding door
sliding door
Postby waynebus0 » Tue May 14, 2013 7:52 pm
HI I HAVE A 2006 MARK 6 TRANSIT 16 SEAT MINIBUS, THE SIDE SLIDING DOOR KEEPS BOUNCING BACK OPEN WHEN I TRY TO SHUT IT, IT WILL ONLY SHUT TIGHT IF I SLAM IT HARD, I HAVE CHANGED THE DOOR RUNNERS AND ALSO THE INTERIOR HANDLE AND CABLE, ANYBODY HAVE ANY IDEAS??????
waynebus0
Re: sliding door
Postby Damien89 » Tue May 14, 2013 8:31 pm
Common problem because the vans are so air tight, lower one of the front windows 1/2 way and it will close with ease, otherwise you will need to slam it.
Damien89
Re: sliding door
Postby loot » Tue May 14, 2013 8:32 pm
I thought the vent under the sliding door stopped this?
07 350 170ps
Ids map here
loot
Re: sliding door
Postby blue estate » Tue May 14, 2013 8:34 pm
Damien89 wrote:Common problem because the vans are so air tight, lower one of the front windows 1/2 way and it will close with ease, otherwise you will need to slam it.
:roll: :lol: :lol:
MGS5 and MG5
VOLVO FH daily drive
blue estate
Re: sliding door
Postby Damien89 » Tue May 14, 2013 9:51 pm
loot34 wrote:I thought the vent under the sliding door stopped this?
The vents are too small to let enough air escape.
Damien89
Re: sliding door
Postby Guy88 » Wed May 15, 2013 1:41 am
Never heard of a transit being air tight.
The minibus windows leak enough to let the air out.
Try adjusting the striker plate further out
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: sliding door
Postby Damien89 » Wed May 15, 2013 5:27 am
Guy88 wrote:Never heard of a transit being air tight.
If he adjusts the striker plate the whole door wont seal properly and water could get in.
I know it for a fact because here in malta we have loads of minibuses and everybody has this problem. Small kids sometimes cant close the door properly because of this problem. Try lowering one of the front windows half way down and see if it solves you problem.
Damien89
Re: sliding door
Postby limitedblack » Wed May 15, 2013 7:10 am
Mine does it sometimes when the kids close the door, but it normally latches on the safety catch. It's true that the air is a problem, I usually drop my window slightly when they're closing the door. So it depends what he means by not closing "bouncing".
Happy Easter
limitedblack
Re: sliding door
Postby loot » Wed May 15, 2013 9:08 am
mine closes fine kids are weak they can't even close the front doors :lol:
but he does need to explain the problem in detail, the last van I had,1 of the 2 locators on the front of the door was loos due to the torx spinning and the locator was cock eyed. :wink:
07 350 170ps
Ids map here
loot
Re: sliding door
Postby wexican » Sun May 19, 2013 10:47 pm
Mines the same . The 14 seaters are a damn sight more airtight than the 16 seaters :D
wexican
