110ps connect egr fault
Postby poolie » Sat Apr 27, 2013 12:58 pm
Eml is on my van had codes read po489 po490 egr fault. Can i clean egr? To stop light coming on? Van is running fine no loss of power.
poolie
Re: 110ps connect egr fault
Postby M@tt17 » Mon Apr 29, 2013 9:06 pm
Mine had same fault P0490 EGR control circuit above maximum threshold but no eml on I blanked it off van runs so much better it had very bad turbo lag but blanking off the EGR sorted it out cleaning it seems to be a messy job blanking it was easier
M@tt17
Postby poolie » Tue May 14, 2013 7:34 pm
Ok ive bought a blanking plate the type with no hole. Fitted plate van runs alot better eml stays on but went off but now its came back on :? If i drill a hole in the plate will this turn the eml out for good?
poolie
Postby CamsTrans » Tue May 14, 2013 10:47 pm
It depends if it's a TDCi or TDDi, the former needs the hole the latter doesn't!
You may get an engine management light flash on with a TDCi still though.. Mine did the other day for about 15 miles. I should probably check the blank is clean at some point.... :lol:
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby LeeH » Wed May 15, 2013 6:23 am
My tdci has a blank with no hole, I asked van tuner. No light as yet and it's been on for a few months now.
LeeH
Postby paul2012 » Wed May 15, 2013 11:41 am
Any problem with the egr circuit will throw on the MIL light & blanking off the egr will not solve the problem.
P0489 Exhaust Gas Recirculation "A" Control Circuit Low
P0490 Exhaust Gas Recirculation "A" Control Circuit High
Euro 4 engine with electronic egr controlled by stepper motor - fitted to connects from 2006 onwards. - Advisable to have whole in blanking plate.
Euro 3 engine with EVP egr controlled by vacuum & position sensor (looks like a UFO) - fitted to connects 2003-2006 - NO hole required in blanking plate
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
