I am changing my EPIC for a Bosch pump. The pump I am fitting has a unit with bellows and a connector on the side
I presume this is a cold start assist? What does it connect to and how does it work?
Many thanks
MinorMatt wrote:I know what it is
And yes its a cold start solenoid fitted from ~94-96.
It connected to a switch which screwed in to the side of the block below the fuel filter.
You wont have the provision for the switch in the block, so you could connect a choke cable to the lever
MinorMatt wrote:It increases the amount of diesel injected... so if you have it on a cable inside the dash you can control the amount of smoke on the move...
Im not sure how well the low pressure (early) pump will work with the later high pressure injectors though
MinorMatt wrote:A 108 is exactly what was originally fitted to my 95 190 LWB 76PSAnd they were fitted AFAIK until late 1995 not 1997 as you suggest in the other thread...
You can't get torque sleeves for them (well I couldn't 5 years ago) so bear that in mind.
Users browsing this forum: longhair
