connect tyres advice please
Postby poolie » Tue May 14, 2013 7:39 pm
I have just been given some new tyres their a slight different size my question will they be ok obviouslyboth on same axel 195/55/r15.
poolie
Re: connect tyres advice please
Postby g-man » Tue May 14, 2013 7:56 pm
what weight rating?.........you need 95xl i believe
g-man
Postby karl » Tue May 14, 2013 8:18 pm
Tyres are tyres in my opinion as long as both are the same on each axle then no problem
karl
Tranny Lover!!!
Postby Altransit » Tue May 14, 2013 9:31 pm
karl mcghee wrote:Tyres are tyres in my opinion as long as both are the same on each axle then no problem
Sadly, that isn't the case, they need to be equal to, or greater than, the weighted rate of the axle (as a pair!) :)
Postby gt_addict » Tue May 14, 2013 9:55 pm
But surely if they are on the front the speedo reading would be incorrect as its a 55 profile instead of a 65 profile?
gt_addict
Postby Marty.H » Tue May 14, 2013 9:58 pm
Yes it will be out. All tyres on a commercial vehicle need to have the correct loading all be it the connect is a class 4 mot and they dont come into it but in the event of an accident or a claim brace yourself :lol:
Marty.H
Postby g-man » Tue May 14, 2013 10:04 pm
you work for qwik-fit? :roll:
g-man
Postby Marty.H » Tue May 14, 2013 10:09 pm
I would say not no mention of leaking shocks and warn brakes at same time :lol:
Marty.H
Postby paul2012 » Wed May 15, 2013 12:05 pm
Connects are classed as LGV, a commercial vehicle NOT car derived van. Hence the correct load index rated tyres should be fitted :!:
gt_addict wrote:But surely if they are on the front the speedo reading would be incorrect as its a 55 profile instead of a 65 profile?
Yes your right speedo would be incorrect.
If 195/55/15 are fitted to the front & you were traveling at 60mph, your actual speed would be 56, plus you would notice a reduction in fuel economy. :(
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby karl » Wed May 15, 2013 12:33 pm
nope meself :D
karl
Tranny Lover!!!
Postby poolie » Wed May 15, 2013 2:34 pm
g-man wrote:what weight rating?.........you need 95xl i believe
580 kg its says :?
poolie
Postby gt_addict » Wed May 15, 2013 3:03 pm
For a t230 connect you need a weight rating of 95 as specified in the manual. Well that's if you want to be legal about it. I ran a set of winter tyres last year with a rating of 91.
gt_addict
Postby g-man » Wed May 15, 2013 5:03 pm
580 kg its says :?
no good for any connect :arrow: http://www.google.co.uk/url?sa=t&rct=j& ... zkwrHAkQFg
g-man
