New clutch and another engine but wont go into gear
Postby Warren D » Mon Apr 29, 2013 9:17 pm
Last week I had an engine out of another transit, fitted in my transit and also a brand new clutch. The new engine is great but after a day or so the van started getting harder to get into reverse, first and second gear. Today I couldn't get it into reverse, first, second, third or fourth. Fifth was ok. I switched off the engine and was able to get it into any gear while switched off so I put it in second and started it up but it started to creep along even while I had the clutch to the floor.
What do you think is going on?
Warren D
Re: New clutch and another engine but wont go into gear
Postby Warren D » Mon Apr 29, 2013 9:26 pm
Sorry, meant to say it's a LWB 2.5 td.
Warren D
Postby AndyG » Mon Apr 29, 2013 9:41 pm
Auto or manually adjusted clutch :?:
Fork split/splitting :idea:
Stretched cable :idea:
Postby Warren D » Mon Apr 29, 2013 9:51 pm
AndyG wrote:Auto or manually adjusted clutch :?:
I don't know, mate. I don't really know much about motors.
Warren D
Postby AndyG » Mon Apr 29, 2013 9:56 pm
Will the person that fitted the clutch not have a quick look for you :?:
Postby Warren D » Mon Apr 29, 2013 10:06 pm
I'm speaking to them tomorrow. I just wanted to find out as much about it as I can before I speak to them. I'm in Spain and there's plenty of people down here will have you over as quick as a shot if they think you don't understand what is going on.
Warren D
Postby Warren D » Thu May 16, 2013 6:19 am
OK, it turns out that the engine is from a LDV Convoy. Can my clutch be altered to fit this? I have seen a clutch kit for a Ford Transit 2.5 diesel, LDV Convoy on ebay. Is this what I need?http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0308235015
Warren D
Postby MinorMatt » Thu May 16, 2013 7:29 am
The engines are the same...
Its common for the clutch forks (assuming yours is a manual) to fracture and stop working (its obvious if you get underneath and look, whilst an assistant operates the clutch
