MK6 axle in MK5
MK6 axle in MK5
Postby Guy88 » Sun May 12, 2013 4:41 pm
As above, is it a strait swap to fit a MK6 axle in a MK5 :?:
guessing the handbrake will be different but does it bolt strait in?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MK6 axle in MK5
Postby MinorMatt » Mon May 13, 2013 2:06 pm
Well the flange sizes on the 6 stud and 5 stud mk5 are different...
I know the spring perches are the same distance apart. Apart from brake lines etc I would think that there can't be a big difference between the dims of a mk6 axle and mk5 6 stud axle?
Re: MK6 axle in MK5
Postby AndyG » Wed May 15, 2013 12:22 pm
Wheel bolts will be different too, unless the half shafts are interchangeable :idea:
Re: MK6 axle in MK5
Postby oldyellar » Thu May 16, 2013 10:49 am
on your spec?
oldyellar
Re: MK6 axle in MK5
Postby Mfr » Thu May 16, 2013 10:59 am
Is this to change the gearing? Because if its a six stud mk5 there may be a chance the crown wheel and pinion will swap over. I had this done for £225 + £125 for the axle but that was a mk5 twin wheeler. But this would need checked out first before committing.
Mfr
Re: MK6 axle in MK5
Postby Guy88 » Thu May 16, 2013 11:25 pm
got a crown wheel and pinion to fit for now,
Its a DRW axle, was thinking of 4.63 and 16" wheels would be idea
And if a MK6 axle fits then a MK7 wouldnt be hard so discs on the back too
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MK6 axle in MK5
Postby Mfr » Fri May 17, 2013 8:55 am
Would you change the front setup to? otherwise you will need to carry 2 spare wheels one 15" one 16". A mate of mines mk6 has a 4.27 rare but they are out there.
Mfr
Re: MK6 axle in MK5
Postby Guy88 » Fri May 17, 2013 9:01 am
Mfr wrote:Would you change the front setup to? otherwise you will need to carry 2 spare wheels one 15" one 16". A mate of mines mk6 has a 4.27 rare but they are out there.
i carry 2 spares anyway :wink:
i think the 4.27 would be too much for the 100ps i have, its got to pull at full train weight most of the time
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MK6 axle in MK5
Postby Mfr » Fri May 17, 2013 9:21 am
Sounds good! discs all round will definitely be good with full payload. Here is a handy web page for calculating rpm, diff one at the bottom. http://www.csgnetwork.com/multirpmcalc.html
Mfr
