Van cutting out after 5 seonds once started.
Postby Rab1988 » Sat May 18, 2013 1:40 pm
Hi all, Was wondering if someone can help out. Replaced the clutch yesterday in my 54 plate Transit with a 2.4 Duratec engine. After this had been completed the engine will not run continually. It starts up and cuts out after 5 seconds and the glow plug light flashes once it cuts off. The engine will restart as many times as required but will not run longer than the 5 seconds. During the work the battery was disconnected. Never had any issues with van cutting out before this.
Any advice/help would be much appreciated, Robert.
Rab1988
Re: Van cutting out after 5 seonds once started.
Postby ake » Sat May 18, 2013 2:03 pm
The crank sensor is either broken, unplugged, or connected to the speedo wiring by mistake
Postby Rab1988 » Sat May 18, 2013 2:24 pm
:oops: connected to speedo wiring being correct, Thank you.
Rab1988
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot]
