So my MK 1 exhaust is on Rumbles, now you have my MK2, wonder who will get the MK3 dual exit
Dale1970 wrote:Mine are the genuine Mako units. as Limited said glue hard to split but put mine in oven at 85c for half an hour and they split quite easy just be patient. Start at the top point and work down both sides and then the bottom. I went round mine with Stanley knife and gradually prised a part with to flat headed screw drivers a bit like removing a bicycle tyre .
belly wrote:Dale1970 wrote:Mine are the genuine Mako units. as Limited said glue hard to split but put mine in oven at 85c for half an hour and they split quite easy just be patient. Start at the top point and work down both sides and then the bottom. I went round mine with Stanley knife and gradually prised a part with to flat headed screw drivers a bit like removing a bicycle tyre .
Well I honestly take my hat off to you guys![]()
I tried the oven but the plastic started melting before the mastic and tried all sorts of ways but just ended up f**** a few
Punto443 wrote:Highlighted my speedo and rev counter with a bit of silver paint![]()
I was bored as it was raining afcukingain!
Punto443 wrote:It's just shite this weatherStill, a few bit to do inside
Finally got my adjustable intermittent wiper working, and fitted a new shades holder, as I got new parrot.
Punto443 wrote:Where's all the sunglasses holders? You've all had them for weeks
