Mk6 starting problem
Postby uniscar » Sat May 18, 2013 2:53 pm
Hi ive got a 2002 mk6 2.0tddi. On a morning it turns over for quite a long time before it will start. It seems like it is getting no fuel but when it does fire there is no smoke at the back. Ive changed the fuel filter housing and heater plugs and the heater plug rail still the same. Any clues
Cheers Dominic
uniscar
Re: Mk6 starting problem
Postby l33uum » Sat May 18, 2013 2:57 pm
Mines started doing this. It was the battery that was failing.
l33uum
Postby Guy88 » Sat May 18, 2013 6:31 pm
whats the glow plug light doing,
does it go with a jump start
If the battery voltage goes below 9v it wont inject fuel
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby uniscar » Mon May 20, 2013 7:45 am
Hi the glow plug light goes out as it should and the battery was changed 6 months ago along with the earth lead under the seat. I dont need to bump it off as it eventually starts but its taking a long time. Once it starts it runs great all day
uniscar
Postby uniscar » Mon May 20, 2013 7:51 am
Just checked the battery and it is showing 13.4v.
uniscar
Postby karl » Mon May 20, 2013 9:03 am
blocked furl filter /fuel starvation /air filter :?:
when were they last changed :!:
karl
Tranny Lover!!!
